#32 |
if you look the last few pages of the ss15 topic,there where some sugestions of alternatives
one good thing about music ,when it hit you feel no pain. so hit me with music.
#33 |
hey what happened to this thread
#34 |
bump
#35 |
pm justint
he has bild them ,and i beleave hes happy with them.
#36 |
My PA is:
Alan Heath Zed 14 (mixer) Crown xti 2000 (amp) 2 Peavey PR12 (for tops) 2 Bjorno subs (as listed in this thread) The xti is set to cross-over at 100Hz, with the Bass Boosted 5 dB and HiPassed at 30Hz and the tops cut at 16 KHz. I chose not to use the ss15 because I really wanted 32 Hz and was willing to accept loosing 3dB of power to get it. In retrospect, that's a high price to pay for 5 semitones of bass. Everyone loves the sound!!!
Don Last edited by Don Snyder; 12th December 2012 at 09:28 PM. |
#37 | |
those look very easy to make for a wood newbie can you post some measurements out from your prototypes ? do you paintes them with duratex ? they look PRO !!!! and you matched the color of the Pr12 so i think i dont need more than Pr12s and a pair of the subs btw, have you tried with just one pr12 and see if the single top can keep up with the 2 subs ? normally the tops outperform the subs, so is almost a 2:1 ratio Subs to Tops ratio, sometimes even higher what to know your findings as the graphs are too low res to really read the numbers can somebody post hi res graphs of the response of this cab ? also some more detailed inside pics to see how the braces are installed , on the Don i cant see Thanks PD what drivers can fit the box Last edited by maxo; 12th December 2012 at 10:48 PM. |
#38 |
Hi Bjorno,
I am not familiar with this type of construction. Could you please comment, as I am curious to learn more about this box. I would assume there will be come cancellation in the bass as the rear and front signal meets in the pipe ? Thanks in advance! Bjorn |
#39 |
Hi Maxo -
Plans? Post 23 Measurements? Compared to SS15, down 3dB Paint? Latex House Paint ... Duratex would be much better. House Paint looks good, but needs retouching after only 3 months. Power? 200W into each top and 400W into each sub yeilds 125dB/1 meter measured as 105dB/10 meters. The Subs are louder than the tops. Braces? I didn't use them and it still works well. You MUST use HiPass of 30Hz and 24dB/Octave on the sub or they will self destruct. There can be NO leaks in the cabinet. Hi Bjohannesen - Have fun ... You have much to learn. Get the HornRes software and read the "JBell" thread "single sheet ..." or anything by "Tom Danley"
Don Last edited by Don Snyder; 13th December 2012 at 10:45 PM. |
#40 |
BUMPING THIS THREAD
Don, thanks for the info one question how the box will work if you remove the front panel if you can see the front panel covers half of the woofer if you see the box facing you does that thing makes some kind of reflections ? or is part of the waveguide for the tapped horn thing ? also i see 2 braces on the cut sheet diagram you made where are those braces needs to be installed and one last question, if the box goes down to 35hz, you seet your high pass to 30 hz ? or 35 hz 24db LR or 48db if you have one, ( i think the dbx driverack only have 24db LR filters ) and voltage limit to 70% of what your driver RMS ratings are ? Ahhhh and i see on post #10 Bjorno listed a comment for the 3015LF at 290watts on his sim, you can read that just below the thiele small parameteres so we limit at 290 watts ? Thanks. Last edited by maxo; 2nd January 2013 at 02:31 PM. |
| simulating "Deep Frame Dipoe" (DFD) Woofers, AkAbak? | mige0 | Software Tools | 19 | 29th December 2010 04:00 AM |
| FS: BG Neo3 PDR - Special OEM "Deep-Back" Version | mac | Swap Meet | 1 | 19th November 2010 04:11 AM |
| 3015lf? | mike james 533 | Subwoofers | 29 | 18th April 2010 01:00 AM |
| Driver in deep baffle"tunnel" | marcus1 | Multi-Way | 4 | 6th December 2009 07:18 PM |
