#11 |
so thats really all there is to this box? 1 board down the center basically, no angles no nothing? Just pull out the saw and glue and i bet i could do one of these in under 2 hours if I tried
#12 | |
b
#13 |
This thing can be made from one sheet of ply! (with minor changes).
Don Last edited by Don Snyder; 27th March 2011 at 09:09 PM. |
#14 | |
The remaining leftover wood can be used to reinforce a detachable driver access-lid and maybe pieces glued to brace the top and bottom too. b
#15 |
Hi Don, may I ask where you found these Thiele-Small parameters from the 3015LF?
#16 |
Interesting box bjorno!
Couple of questions: Does this need a high pass like a tapped horn and could one fit the driver the other way around (again a la TH) for ease of access if one reverses polarity? Thanks! |
#17 |
Bjorno - no need for access panel, I simmed it in CAD and it went in with an inch to spare.
Djim - Eminence has brought out a new version of the 3015LF but I'm still using the old version numbers.
Don |
#18 |
Justin, I think you should check your 3015LF's first because the 'new' version seems to be quiet different.
#19 |
The difference in Don's design:
#20 | |
You don't need any HP-filter at all if you stay below~63W input( i.e. ~ 116 SPL and 1 Hz safe). Mount the driver like a TH or a T_TQWT: The performance differences will IME be benign, but mounting like an TH has an advantage when stuffing is used as it's easier to minimize the minimum required stuffing for smoothest response (sometimes needed (Hi-Fi)) and if used, would be easier to evenly distribute the damping material at the 'throat side' whereas otherwise would be occupied of the basket and magnet volume. Thanks again Don !: I oversaw the possibility to avoid using a lid, I'm too focused on T-TQWT designs where an access lid is an evil necessity to incorporate.b
| simulating "Deep Frame Dipoe" (DFD) Woofers, AkAbak? | mige0 | Software Tools | 19 | 29th December 2010 04:00 AM |
| FS: BG Neo3 PDR - Special OEM "Deep-Back" Version | mac | Swap Meet | 1 | 19th November 2010 04:11 AM |
| 3015lf? | mike james 533 | Subwoofers | 29 | 18th April 2010 01:00 AM |
| Driver in deep baffle"tunnel" | marcus1 | Multi-Way | 4 | 6th December 2009 07:18 PM |
