Keystone Sub Using 18, 15, & 12 Inch Speakers - Page 18 - diyAudio
Old 27th August 2013, 03:56 PM   #171
weltersys's Avatar
Originally Posted by sine143 View Post
hey art, you think its safe to say that this cab in real baltic birch is gonna come in around 180 to 200lbs?
With lightweight 3/4" plywood and the BC18SW115 the Keystone came in around 150 pounds.
From what I can tell, BB ranges from around 2.6 to 3 pounds per square foot.
The Keystone with the BC18SW115 should weigh around 175 pounds if the BB is around 3 pounds per square foot, using the the BC18TBW100 instead would add another 7.1 pounds.
Old 27th August 2013, 04:11 PM   #172
epa is offline epa  Netherlands
bb is for 18mm 12.78kg/m2
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 27th August 2013, 04:27 PM   #173
weltersys's Avatar
That would be on the light side for Baltic Birch, equivalent to about 85 pounds for a 4x8.
Using that density, the Keystone should come in under 175 pounds (79.5 kg) even with the BC18TBW100.
Old 27th August 2013, 06:11 PM   #174
i looked for this information myself a while ago.
but i never measured it.
for b/bb grade
18mm 12.78kg/m2
15mm 10.65kg/m2
12 mm 8.52kg/m2
10 mm 7.1kg/m2
8mm 5.68kg/m2
edit/ found this
. hr driver db
Old 27th August 2013, 08:30 PM   #175
sine143 is offline sine143  United States
Im teetering on the edge of building a couple... bcsw115 at 508 shipped from parts exprss, found some tbw100s for around 350 shipped, meaning the tbw loaded would run me about 475 after wood/glue/hardware, the sw115, about 630.
Still dont have enough fire power to get them to xmax tho
Old 3rd September 2013, 10:48 PM   #176
Default Cutlist
ok, so I have been using Ubuntu for about 1 1/2 years and love it until today. I have cutlist installed via WINE and it will not show solution of the board layouts for the keystone. e Even when i manually drag the boards it freezes up repeatedly. Can someone post the cutlist please??
Old 4th September 2013, 12:19 AM   #177
weltersys's Avatar
There is a board layout for a pair of Keystones in the right hand side of the sketch in #63.
Takes three 3/4" 4 x 8 sheets for a pair.
Old 13th November 2013, 03:41 AM   #178
allllright. so I've finally convinced a friend to go halfs with me on 4 keystones. We had initially planned to drop the extra cash on the Sw115. Arts indicating it might be more prudent to just go with the tbw100. Weight is not a concern.
All I have available is my xti 4002 (doubtfully useful), and his LG 14000 Clone amp (a suppossed 4500 watts at 4 ohms per channel). I'm more than happy to plug that clone up to a 30 amp or even 50 amp service if need be... the real question is if we can make use of the Sw115s power. If there's no audible difference, I have no issue going with the tbw... the fact that we're getting 4 means I'll get a pretty discount on them (I'd need to get 12 sw115s to get a similar discount).
Old 13th November 2013, 07:21 PM   #179
weltersys's Avatar
The xti 4002 bridged mono would power one four ohm cabinet nicely.
Whether you would notice the 2 dB difference using a 18SW115-4 driven at 82v compared to a 18TBW100-4 at 64 volts is hard to say.
I don't think I'd notice a difference unless it was an A/B test.
Have fun making sawdust!
Art
Old 13th November 2013, 07:49 PM   #180
I will. do you mind if I post a 3d model of the cab here? I still need to add bracing... and I had a quick question:
is there a "spacer ring" for mounting the 18" woofers? I notice the cut out is only Sixteen inches
Ne 5532 15+15 or 18+18 east electronics Solid State 3 26th January 2010 12:43 PM
Which amp for speakers with a Fountek Neo Pro 5i and 12 inch woofer boidos Pass Labs 1 24th June 2009 09:10 AM
Two 10"inch and two 12" inch subwoofers and what to do?? Gentle1Man Subwoofers 25 13th March 2008 09:00 AM
Two 8 inch usher vs one 12 inch M&K qguy Multi-Way 0 25th October 2006 10:54 PM
Copyright 1999-2017 diyAudio
