Old 9th March 2013, 02:48 PM   #161
tb46 is offline tb46  United States
Hi CRESCENDO,
Post #159: "...making it 3" taller, 2" wider and *maybe* 1" deeper..."
How do you make something "...maybe...deeper...", and arrive at an accurate drawing?
Anyway, I'll give it a try with 48"H x 28.5"W x 23.5"D just to give you some numbers.
Oliver
Old 9th March 2013, 08:46 PM   #162
Hi Oliver,
If the depth of the cab is worth stretching another inch vs a negligable difference. I do have that room to spare, so go ahead and use that to your advantage, if needed.
If you haven't started yet, don't worry about it. I miscalculated something and 48" is too tall :/ and I'm doubting the other small changes are enough to make it matter... Apologies in advance if you've already been plugging away.
Old 10th March 2013, 03:19 AM   #163
Hi CRESCENDO,
To make a long story short, stick with the original Keystone design. Art has obviously put a lot of work into this, and the improvements from changing the external dimensions are minimal.
Oliver
Old 10th March 2013, 03:49 AM   #164
Hi Oliver,
Yeah, I agree. Might as well experiment with different sq ft openings to get a few extra LF dB like his image shows (posted a few pages back). Might not hurt to experiment with the TH18s I have as well.
Justin
Old 10th March 2013, 06:57 PM   #165
Originally Posted by PASC View Post
Hi!
One box with 18NLW9600, into a big warehouse, floor concrete, around 8 M from nearest wall, just in front of the gate where trucks can pass into place.
Pasc,
What is the dB scale on the RTA?
File Type: jpg Screen Shot 2013-03-10 at 12.55.20 PM.jpg (62.5 KB, 135 views)
Old 11th March 2013, 12:58 AM   #166
PASC is offline PASC  Brazil
Hi Welter!
Graphic EQ 1/3 octave, +16, -16dBs, in steps of 0.5dB(true response) as per manual.
PASC
Old 11th March 2013, 11:55 PM   #167
18Hurts is offline 18Hurts  United States
Very interesting,
I have some stoutly built bass bins of outside dimensions 40" H X 18"W x 24"D and wonder about building a 15" version. 5.5 inches too short for an 18 but a 15" would gain 3 inches of S2. Can I get away with an inside width of 16.5" instead of the 24" width of the 18" version since I'm running the same depth (actually, it is deeper by 1.5" so I can lengthen S2 by another 1.5 inches and get really close)
Yes, I'll struggle my way through horn response to get an idea, but wondered if the Keystone is sensitive to that kind of manipulation?
My initial though is to use the JBL GT5 15" car woofer which uses the
same motor as the GTO 1214--with a larger cone. Since it has a much smaller Vas than traditional PA speakers, can I assume it won't need to be as wide? Final amplification is just 200 watts so not much of a need for a BL product higher than it's rated 16.7 (I'm assuming)
Just a set of bins that do 32 to 150Hz is all I need for the garage, I do have the options of not using the JBL 15 but with 200 watts to play with, no need for B&C monsters either. I would like to generate
121 dB with two of them driven with two 200 watt amplifiers for sound testing at the local church so the closer, the better.
In summation, if I use a 15" and make the path the same length, the depth is the same--can I narrow the cabinet because of the smaller woofer or is that a no go for Keystones? I prefer the Keystone over the typical 18" BR since they are protected from various things behind the keystone panel and prevent teenagers from becoming fascinated by watching woofers stroke (not sure why they do but....) Part of my idiot proofing concept...
Thank you!
Old 12th March 2013, 12:50 AM   #168
Thank you!
The path length will be a bit shorter which will raise the F3 a bit.
That said, I had to reduce the exit size for the 15" to keep a similar LF response as the 2x12" and 18". Reducing the exit size further makes the cabinet go lower, but also drops the level.
Reducing cabinet width may actually be an improvement for a 15", but you will need to experiment with the exit size. As a starting guess, I'd reduce the exit dimensions by the same % as the cabinet width and height are reduced.
Since you have the existing cabinet shells, might as well go for it.
Old 12th March 2013, 01:38 AM   #169
Thank you so much!
As a garage system, the keystone will cover the 15 from flying parts, oil, beer and kids. As you say, I have the shells of stout 3/4" ply and noted the ratio is close to the 18" version. If I can get a gain of efficiency of 3dB over the stock 90dB of the JBL--anything extra is gravy. A pair of those with 200 watts each should be more than enough for BBQs and noise complaints.
Now to practice with horn response, gather up some spare wood and get those 15's on order. Thank you for your assistance and guidance and I'll start making sawdust in a week or two.
Ne 5532 15+15 or 18+18 sakis Solid State 3 26th January 2010 12:43 PM
Which amp for speakers with a Fountek Neo Pro 5i and 12 inch woofer boidos Pass Labs 1 24th June 2009 09:10 AM
Two 10"inch and two 12" inch subwoofers and what to do?? Gentle1Man Subwoofers 25 13th March 2008 09:00 AM
Two 8 inch usher vs one 12 inch M&K qguy Multi-Way 0 25th October 2006 10:54 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
