Keystone Sub Using 18, 15, & 12 Inch Speakers
Old 9th May 2018, 09:34 PM   #1201
Brian Steele is offline Brian Steele  Grenada
Originally Posted by weltersys View Post
5) There are many that complain about resonant behavior, but a 1/4 wave resonator cabinet won't work without it.
But you can push those unwanted resonances way out of the cabinet's intended passband so their audible impact is noticeably less, hence my interest in offset slot-loaded tapered TLs. Efficiency is a bit lower than a THs, but box size requirements are also lower, and out of band resonances can be pushed an octave above typical cabinet passband (~100 Hz) and they are also lower in level compared to the passband. Terminating the TL with a slot results in an Fb that's lower than a vented box of the same net volume (and the extra internal panels double as bracing), and the use of a slot instead of a full taper allows some flexibility in locating the offset to obtain the best results when the TL is folded up into a box.
An alternative approach is to design and build the TH using the process I outlined in this thread: Ooh looky - a TH that does from ~42Hz-500Hz +/-3dB
It does result in a slightly larger box though. I'm considering a redesign of my POC3 build to incorporate the larger S1-S2 volume to see if the results to match the sims.
www.diysubwoofers.org
Old 10th May 2018, 04:35 PM   #1202
treukauf is offline treukauf
Thanks everyone for the input. Brian, I read through your thread, and thats interesting. I am trying to learn REW now to better evaluate and tune my behringer nu/dsp amps. Going to try to test and review all of my subs this summer.
Old 24th June 2018, 01:17 AM   #1203
radulescu is offline radulescu  Romania
Weltersys, it seems that all your discussions about the sensitivity graph on Danley's TH118 being 3 dB higher than it should, made them measure it again and it seems now that they have changed it. Cheers
Old 24th June 2018, 02:10 AM   #1204
Do you have a link to the new measurements?
Old 24th June 2018, 11:16 AM   #1205
Osse is offline Osse  Sweden
TH118 | Danley Sounds Labs | Danley Sound Labs, Inc.
Took some time for them
Old 24th June 2018, 04:34 PM   #1206
weltersys is offline weltersys  United States
weltersys's Avatar
Funny, the 2.83V/4 ohm "sensitivity" is 105 in the Architect/Engineer Specs, while it still is 108 in the "key features" area of the spec sheet.
Same mistake in the larger TH118XL specs. The TH118XL has about +3dB more output at 30Hz than the current TH118 (but less than the old TH118 measurement...)
Sometime around May 2018 they had updated the TH118 impedance chart (the 18Sound driver in the original TH118 had an impedance minima of 3 ohms)without changing the frequency response chart. Oddly, the lower impedance minima somehow went up from around 28 to 35 Hz.
No impedance charts were included in the current TH118 or TH118XL spec sheets, but the frequency response has been re-measured, probably when they noticed the previous TH118 appeared more "sensitive" than the larger TH118XL.
Old 24th June 2018, 04:48 PM   #1207
The FR graph for the TH118 seems to show it hitting around 108dB/2.83V/1M at just over 100 Hz. Between 50 to 100 Hz, it's around 105dB/2.83V/1M, and slopes off below that.
Now THAT I'm more interested in. I remember having a lot of discussion with JAG over that, him insisting that the minor changes in the TH118 compared to the TH115 of the same dimensions is what caused the lowest resonance frequency to drop to 28 Hz, and me responding that there was no way those minor changes could have made such a significant difference in the resonance point.
https://www.danleysoundlabs.com/danl...ecs-V2.0-1.pdf
Old 24th June 2018, 05:25 PM   #1208
weltersys's Avatar
The LF impedance response of the BC18SW115-4 TH-118 appears to have changed back to being more similar to the TH-115 in the more recent (bottom chart) measurement, compared to the older 18 Sound loaded TH-118 (center chart).
Old 24th June 2018, 06:05 PM   #1209
Yup, that's exactly what I'd expect the impedance curve of the TH118 to look like.
Interestingly, the spec sheet indicates that the TH118 goes down to 29 Hz, which is below the lowest impedance mininum...
Old 24th June 2018, 06:13 PM   #1210
Moderation Team is offline Moderation Team
Moderation Team's Avatar
@Art & Brian - please stop quoting the post directly above yours when replying. See diyAudio Rules
Please note: PM's sent to this account will not be answered.
Keystone Sub Using 18, 15, & 12 Inch SpeakersHide this!Advertise here!
Ne 5532 15+15 or 18+18 east electronics Solid State 3 26th January 2010 12:43 PM
Which amp for speakers with a Fountek Neo Pro 5i and 12 inch woofer boidos Pass Labs 1 24th June 2009 09:10 AM
Two 10"inch and two 12" inch subwoofers and what to do?? Gentle1Man Subwoofers 25 13th March 2008 09:00 AM
Two 8 inch usher vs one 12 inch M&K qguy Multi-Way 0 25th October 2006 10:54 PM
