Old 18th March 2011, 11:59 AM   #1
DQ828 is offline DQ828  Australia
DQ828's Avatar
Default Sub for the Daughter
I need to start designing a sub for the daughters birthday does anyone know if theses drivers are any good. Tymphany LAT700. I know vary little about subs but have to start somewhere.
David
Old 18th March 2011, 04:21 PM   #2
DJNUBZ is offline DJNUBZ  United States
That sub is ok but it still requires an enclosure and it is an oddball. I would recommend a traditional subwoofer driver. What size enclosure are you considering.
Old 18th March 2011, 10:23 PM   #3
DQ828's Avatar
As small as possible.
I was also thinking maybe something along the Ripole lines.
David
Old 18th March 2011, 10:40 PM   #4
revboden's Avatar
David
We would need more information on how the sub is going to be used, integrated, room size, home theater or music, any additional details will help.
Old 19th March 2011, 11:20 AM   #5
chris661's Avatar
Yep, the 6.5" Tang Band subwoofer in a small box would work.
Tang Band W6-1139SI 6-1/2" Subwoofer
plus
Dayton Audio SA100 100W Subwoofer Amplifier
Would probably do. Still, if it's a massive room, or silly SPLs are required, then one of those might not be enough.
What's the budget?
Chris
Edit - just realised your location. Perhaps something from Peerless would be available?
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 19th March 2011, 11:48 AM   #6
DQ828's Avatar
It's just for music, I will use a Mini DSP as the crossover it will be temporarily used with a pair of my old KEF speakers. The rooms probably not worth considering as it will move around as she does, where not really after audiophile here, just something that will be good at making a far amount of noise below say 80-100 hz, I haven't measured the old KEF's as yet to know how low they go.
I like the whole Ripole idea as the speakers I have built for myself are Dipole & I think it's best if the box is kept small as possible.
David
Old 19th March 2011, 11:50 AM   #7
DQ828's Avatar
plus
What's the budget?
Chris
Thanks, I will look into it, I have an IcePower mudule I'm going to use to power it & MiniDSP to control.
Old 19th March 2011, 01:18 PM   #8
6.5" subwoofers make me sad
How about something like this?
WoofersEtc.com - SWS-1023D - Alpine 10" Type-S 900 Watt Dual 2-Ohm Subwoofer
Old 19th March 2011, 04:42 PM   #9
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Shipping to Australia makes OP sad...
Dan
Old 19th March 2011, 06:03 PM   #10
I didn't notice his country of origin... Australians sure get the short end of the stick when it comes to prices on a lot of stuff. I am on a few woodworking forums and it seems Australian woodworkers are somewhat limited in their tool choices as well unless they want to pay massive shipping charges.
FNG in over his head trying to make his daughter happy Warrant Everything Else 15 7th January 2011 07:09 PM
Daughter blew up my favourite amp. hybridfiat Chip Amps 41 4th September 2010 12:16 PM
My daughter LM3886 & LM1036 Amp is finished ! sayang001 Chip Amps 19 15th March 2005 01:22 PM
Page generated in 0.15310 seconds (59.37% PHP - 40.63% MySQL) with 10 queries
