Old 16th March 2011, 06:50 PM   #1
kg77 is offline kg77  United Kingdom
Default mini sub for 2.1 system
hi all. i have a pair of event tr-5 monitor speakers,iam wanting to add a mini sub.something that wont over power the monitors.
i dont want the sub to be boomy or loud.
event tr-5 specs:
• LF Driver: Magnetically shielded 5.25 in. mineral-filled polypropylene cone with 1 in. diameter high-temperature voice coil and damped rubber surround
• HF Driver: Magnetically shielded 1 in. diameter ferrofluid-cooled natural soft dome neodymium
• Frequency Response: 53Hz - 19kHz
• ±3dB
• ref. 500Hzz
• Power Output (SPL): >105dB
• Crossover: 2.6kHz
• Dimensions (W x H x D): 7 x 10 x 9 in.
i have looked at many design ideas and iam still confused which way to go.
hoping i could use a 6.5 inch driver or smaller.?
ideally would be as small as possible,driver and box. will comprimise to get 40hz.
sealed box,vented box, tapped horn ?
is for a small room, 2.1 system.
using bassbox pro the best one seemed to be a basic vented box.not exact figures below is from memory :}
0.6 cubic feet
17x10x8
2 ports: 1.5 inch x 8 inch
this gave a f3 of 38hz.
tapped horns or t-line ideas inspire me more but iam lost for whats best option.?
thanks.
Old 18th March 2011, 02:47 PM   #2
thanks for the amazing responses :}
this is the type of subs iam looking at.
http://abluesky.com/products/sub-8-mkiii/
Adam Sub 7 Pro Subwoofer in Matt Black at Gear4Music.com
Gemini
is it possible to self build a sub to that quality ,including the filters/crossovers for a reasonable price ?
is it possible to make a unique design that would still work as well ?
what would be my best solution ?.
Old 18th March 2011, 03:13 PM   #3
Sheldon is offline Sheldon  United States
http://http://abluesky.com/products/sub-8-mkiii/
Gemini
Something like this would be a good fit, with the recommended enclosure: https://www.madisound.com/store/prod...oducts_id=8234
Depends on what's available in your area. You can likely find a suitable plate amp on e-bay.
Sheldon
Old 18th March 2011, 03:47 PM   #4
anyone know uk based stores/sites ?
prices seem crazy in comparison to your link.
also..
would it be possible to use this amp and build a passive sub with crossovers/filters?:
50 watts per channel into 8ohms from 40Hz-20kHz at no more than 0.08%THD
thanks.
Old 18th March 2011, 04:51 PM   #5
Peerless 830946 Sub-woofer
this is best price/site ive found so far.
Old 18th March 2011, 05:39 PM   #6
not to diss anyone , but i had good experiences with the peerless sub , it had more xmax then a 6.5" ( a 3"/4" , can't remember ) .
Sadly , i borrowed it only . ( obviously , i don't care about space usage . )
I'm still back to my circa 90's JBL GT82
Damn , it's 4.5 db much better then my brandless 6.5" woofer driver .
Old 21st March 2011, 01:41 AM   #7
what would this box do ?
Old 21st March 2011, 08:38 AM   #8
chris661's Avatar
Not as much as you might hope.
I think a small vented (or PR) design would be the way to go, using a 6.5" or 8" woofer. There's lots of designs out there, and the TB woofer is available here in the UK (europeaudio.com)
Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 21st March 2011, 11:05 AM   #9
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Originally Posted by chris661 View Post
..There's lots of designs out there...
Hi Chris,kg 77
FYI:
Small subwoofer using Peerless 830946 - diyAudio
b
Aiwa Mini System won't read CDs Uncertain Digital Source 2 6th October 2010 06:38 AM
Sony/Eastech from a mini system Eratosthenes Full Range 0 15th May 2009 11:42 PM
JVC EX-A1 mini system $175 nodiak Swap Meet 0 14th January 2007 04:32 PM
Broken mini system dual1ty Everything Else 1 3rd July 2006 12:45 PM
upgrade amp in mini-system chuck55 Chip Amps 6 9th July 2005 07:08 PM
Page generated in 0.20730 seconds (48.07% PHP - 51.93% MySQL) with 10 queries
