Horn Extender/Wave-guide for TH
Old 14th January 2012, 05:36 PM   #11
Djim is offline Djim  Netherlands
Hi Ben,
Thanks, but I don't use fancy software for that, just draw them in Paint.
Nope, they don't have to flare out if you know what you are doing. Large waves don't see anything that small. You can even make your TH out of 6 straight sections if it doesn't need to play above its full wavelength. This one was another rough idea to make the SS15 (Xoc1 optimised version) couple better in stacks, loaded with the Monacor SP15/500FH.
Old 14th January 2012, 05:58 PM   #12
salzburgsoundsystem is offline salzburgsoundsystem  Austria
Default Nice
Your paint skills certainly exceed mine!
Occasionally I have seen a few quite pricey subs extended like this...
though I must say, years ago when I saw my first one, I thought it was BS - a bass reflex box with the sides, top and bottom extended forward maybe 3 times the depth of the cabinet!
This does of course mean that we could make a 19mm sleeve that slides completely over the cabinet for transport / storage and extends when in use by sliding out.
It could be braced very much like you have indicated at the front, maybe I'd add diagonal or angled bracing.
Regards, Ben
Old 14th January 2012, 06:09 PM   #13
Default Would something like this have a greater effect?
http://sp3.fotolog.com/photo/19/50/9...65648953_f.jpg
The Levan horn extension
or does one design make the system more directionalClick the image to open in full size. whilst another increases efficiency or lowers cutoff?
Regards, Ben
Old 14th January 2012, 06:14 PM   #14
Hi Ben,
In the end he used a iron frame with mash front and for attachment he used 'butterfly' connections, as used in flightcases. It seems to work very well and he uses the extension units for storing his cables. The goal was freq. extension to 40Hz and had to fit in his station car with a max of 400Euro for 2 drivers.
Yes, it does improve coupling in stacks gives an improved directivity pattern and some low end extension.
Old 14th January 2012, 06:23 PM   #15
Default flat to 40Hz
is very good for a cabinet that small and efficient! I am thinking about building an extender for my sixpack, once that is complete.
And now I'm off to make some sawdust!
Regards, Ben
Old 14th January 2012, 06:26 PM   #16
Btw the extension for Xoc1's optimization of the SS15 is 27,2cm deep, but it will do for the standard SS15 as well.
Old 15th January 2012, 12:04 AM   #17
Edit: 3015lf is the old version
Old 15th January 2012, 01:54 AM   #18
djlivex is offline djlivex  United States
I am thinking about putting a horn mouth attachment infront of Marc O. Double MBP-46 getting the wood in two weeks, I will put up pics when I start, thanks!
Old 15th January 2012, 02:15 AM   #19
Hi Djlivex,
A reflector like 'side ears' that Art suggested will work but a true extension of the system will give troubles since it is a 'tuned' bandpass and not a 1/4WL horn or pipe.
Old 15th January 2012, 04:11 AM   #20
Huh, so you think it wont work in Marc's MBP-46 I was planning to build 2 MBP in one enclosure and building an extension piece about 20" long horn mouth extender same angle as the horn mouth? Thanks!
Horn Extender/Wave-guide for THHide this!Advertise here!
guitar speaker horn/wave guide? pzung Full Range 1 30th January 2010 11:53 PM
Short Tractrix tweeter wave guide domtw Multi-Way 3 3rd May 2009 04:05 AM
Pair of Selenium D210Ti and JBL Wave Guide xecluded Swap Meet 7 5th December 2008 08:07 PM
Anti-Wave Guide Computer Case ? Suggestions ? musicphile Everything Else 6 4th February 2007 01:51 PM
what is a wave guide? Joules Multi-Way 7 12th May 2005 02:25 PM
