Old 10th March 2011, 02:50 PM   #1
leo5 is offline leo5  Canada
Default 421-8H II bass reflex design
I have been working with the T/S parameters for designing a bass reflex enclosure for my Altec 421-8H II speaker. But they come out with a 2.3 cu ft box (ideal alignment?). Now having a small enclosure suits me fine, but a good sound is a priority. I play bass & electric piano. I want to build 2 boxes (I have 2 speakers), using only one for small venues and 2 for larger ones. I don't have an amp at this point ( I prefer tube amps), and that is another topic I want your advice on; which one do you recommend?
All or any help will be greatly appreciated
Thank you
Old 10th March 2011, 11:22 PM   #2
Speakerholic
Cal Weldon's Avatar
I would do a take off from the dimensions in the link. The 1233 uses the 421 8LF but you could use the same size cabinet. Keep in mind the recess for the grill.
http://www.altecpro.com/pdfs/vintage...r%20System.pdf
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
tiny bass reflex design? xdissent Full Range 7 13th May 2008 09:57 PM
HELP! Bass-reflex design for vintage University woofer C-15HC davidbosch Subwoofers 9 12th December 2007 02:26 PM
FS: Altec 15" woofer 421-8H Zero Cool Swap Meet 5 1st June 2006 12:12 PM
Lambda TD12s Closed Box / Bass Reflex Design akunec Multi-Way 7 13th September 2005 02:44 AM
Bass Reflex design using MJK software teodorom Multi-Way 2 23rd May 2004 05:16 PM
Page generated in 0.15581 seconds (35.16% PHP - 64.84% MySQL) with 11 queries
