Old 7th March 2011, 11:09 PM   #1
Default A different type of "TH"?
Please critique this design....
Old 7th March 2011, 11:15 PM   #2
BP1Fanatic's Avatar
TRIO8 "Unhorn" Proof Of Concept - Home Theater Forum and Systems - HomeTheaterShack.com
Old 7th March 2011, 11:18 PM   #3
My own is quite different - check the displacement graph.
Old 8th March 2011, 12:13 AM   #4
jbell is offline jbell  United States
how many dog food cans?
Old 8th March 2011, 12:25 AM   #5
LOL! None at all this time . I was messing around in HornResp and decided to try out a few designs based around 1/2 wavelength, rather than 1/4 wavelength. This is one of the designs that popped out. Box size increases a little, but cross-section requirement does go down a bit and there's more excursion control below the passband (it might even be possible to run this without a HP filter, considering that the excursion is reduced all the way down to just above 20 Hz). Out of band noise above the passband is also reduced (and is likely going to be further reduced by the folding required to get this alignment into a box). End result seems to be a passband of 42 Hz to over 120 Hz, and 5dB of gain in the passband...
Of course this is all theoretical for the moment.
Old 8th March 2011, 01:09 AM   #6
I've simmed several 'bow tie' TH's, but never built one...
Let me know if you make saw dust on this.
Old 8th March 2011, 01:27 AM   #7
If I do, it won't be for awhile. Medical issues have curtailed my sawdust-making activities for the moment.
Old 8th March 2011, 05:17 PM   #8
Patrick Bateman's Avatar
I might have to build one of these!
I do a lot of car audio, and have always faced a conundrum with horns. Tapped horns offer smooth output, but suffer from too much upper bass in the car. The problem is that you want the response to fall verrrrrrrrry slowly in the car, to complement cabin gain.
So the flat smooth response that you get with a TH is great for the house, but a little iffy for the car. (Of course you can just EQ it in the car, and that's exactly what I do.)
Front loaded horns work nicely in the car. But the problem that you run into with FLHs is power handling. Unless you drive a van, a single eight is about the biggest you're going to squeeze into the car. Fitzmaurice's autotuba is a good example. If you try to use a ten or a twelve, box size just gets nuts in a hurry. And if you opt to undersize the horn, you might as well just build a bandpass box because the response of a FLH gets really peaky as you undersize it.
So your "bowtie tapped horn" is a really nice option. It sacrifices the low frequency output of a conventional TH, but again, that can be a *good* thing once you factor in cabin gain. And the excursion reduction will certainly keep a lot of woofers from exploding.
I've attached a quick schematic using the Soundsplinter RLI-P8. Once graph is a TH-Mini style layout, and the other one uses your "bowtie" layout.
Old 9th March 2011, 04:13 PM   #9
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
FYI,One more picture to look at...
b
Old 9th March 2011, 04:34 PM   #10
b
Thanks. What's "BS-TH2P" and "BS-TH2M" representing? I think I can make out the others - looks like you've simmed the response with a 20 Hz to 120 Hz active bandpass filter. What's your view on the projected results?
Harrison type "K4000" (K 4000) MKII 2x1000W/4ohm tiefbassuebertr Solid State 25 23rd March 2011 08:52 PM
A "Patchwork" Type Concept Amp Stormrider Solid State 43 5th May 2010 11:00 AM
"BD Pipe"-type speaker using FR125S and WR125S? Brisso57 Full Range 0 6th August 2007 11:20 AM
what type of digital coaxial cable is "in" right now? RemoGaggi Digital Source 1 12th December 2006 02:03 AM
Membrane to limit "unloading" in ported-type enclosures? Datoyminaytah Multi-Way 6 18th August 2004 05:36 PM
Page generated in 0.16761 seconds (59.45% PHP - 40.55% MySQL) with 11 queries
