Old 6th March 2011, 09:49 AM   #1
Boscoe is offline Boscoe  United Kingdom
Default Sealed or ported? Two projects which one?
Okay I want a small compact subwoofer should I go for the Hivi SP-10 in a sealed enclosure or a Peerless XLS 269 in a ported enclosure.
Both systems are 18l.
SP10 pros.
That 'tight' bass sound.
Looks of the driver!!
Easier to build.
SP-10 cons.
Massive 250W power consumption for 5db less.
XLS 269 pros.
Higher SPL and far less power consumption 100W.
XLS 269 cons.
Higher cost.
More complex build.
Supposedly wooly bass?
I would go for the peerless driver, I just want to know whether this tighter bass really exists in reality?
Boscoe
I thought about it once, but then thought again.
Old 6th March 2011, 10:23 AM   #2
Did it Himself
richie00boy's Avatar
Wooly bass from ported boxes only applies to poorly designed boxes. It's going to be a squeeze trying to get a big enough port into an 18 litre box.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 6th March 2011, 03:02 PM   #3
chris661's Avatar
Perhaps a passive radiator design would be better (than ported), as it'd avoid many of the issues surrounding ports.
I'd go for a sealed design myself, though that'd depend on design constraints - how loud/low do you want it to go?
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 7th March 2011, 12:56 AM   #4
nigelwright7557's Avatar
I put the port in the rear of the box as there was no room at the front.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 7th March 2011, 01:11 AM   #5
norman bates's Avatar
I second the passive radiator.
And yes, absolutely, tuning at or below 27hz, ported sounds great.
I like a deep unboosted sealed too (F3 near 30hz) but that usually requires large driver that wants bigger than 5ft3. I have my eye on a pair of the 15" dayton hf's I think (5.2ft3, qtc .707, Fsb=f3=30hz).
Norman
Old 9th March 2011, 06:51 PM   #6
the transient respons is always slower of a bassreflex,higher mass, ,q is higher ,therefor more pronounced basic bass resonance, i would choose sealed,cause the overall performance is much better ,a bass reflex usually sounds coloured, due to harmonics resonance in tube port ,combfilter effects,can maybe be affoided by using a steep active 24 db/octave butterworth filter,to elliminate combfiltereffects
Sealed vs Ported (Rythmik) audioferret Multi-Way 3 30th December 2006 11:31 PM
sealed vs. ported sonu Multi-Way 25 9th May 2005 12:50 PM
Sealed or ported? mazeroth Subwoofers 13 23rd November 2004 12:44 PM
¿Sealed or Ported? eXn Car Audio 28 11th October 2004 11:05 PM
DPL12: Sealed or ported? needtubes Multi-Way 4 1st July 2004 12:42 AM
Page generated in 0.08002 seconds (80.56% PHP - 19.44% MySQL) with 10 queries
