Old 6th March 2011, 01:10 AM   #1
Default Newbie needing help on small sub
Ok all you experts can you help a newbie out? I am in bad need of so bass for my HT/Audio set up. I am planning on adding two of Jim Holtz's Statement Monitors so my current speaker set up is of little value. I am an experienced woodworker and have a full woodshop so construction will be of no problem.
I have looked at the Tapped horn 25Hz design and thinking it just might be to tall. Can it be set on its back firing upwards? Will this effect the sound quality? I have also been looking for a ported or 4th order box for a 10" Sub. Can anyone recommend a Speaker to use in the sub $200.00 range and a design?
Chuck
Old 6th March 2011, 08:21 AM   #2
chris661's Avatar
Peerless do some good stuff. There's a lot of woofer+PR (passive radiator) designs for those, reports are good, though I've never heard one myself.
Tapped horns are a good way of getting lots of bass from a relatively small driver. However, the cabinets tend to be large, so several larger woofers in a more conventional cabinet may be more impressive (in terms of the visual effect). It's personal preference: I don't mind huge boxes, but drivers are expensive to ship over here, so I bought a pair of the Tang Band 6.5" subs, and built a pair of (25Hz) tapped horns. They're very good, go nice and low and I haven't managed to get any nasty sounds of them yet (ie, speaker hitting mechanical limits)
Hopefully, this website will load for you (it's not loading for me atm): it'll give you some background info on different cabinet types.
LDSG Appendix A - Enclosures
Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Newbie needing help to trouble shoot. Ross T Multi-Way 3 26th March 2010 02:05 AM
newbie, needing help with vintage capacitors? Joshua_j Parts 8 10th April 2009 06:32 PM
Small value caps (newbie alert) alphabeta Solid State 3 18th September 2005 10:12 PM
Newbie Needing Project Design Advice cwoodall Everything Else 1 23rd August 2005 04:27 AM
newbie needing some advice TheDarkside Parts 4 13th November 2004 07:51 AM
Page generated in 0.08641 seconds (55.19% PHP - 44.81% MySQL) with 10 queries
