I have an extra pair of SEAS Prestige L26RFX/P lying around around and was considering using them as a pair of sealed stereo subs. Any reason why I shouldn't? Or should I sell them and pick up a single L26ROY?
Thanks!
"If it measures good and sounds bad, -- it is bad. If it sounds good and measures bad, -- you've measured the wrong thing." Daniel R. von Recklinghausen |
#2 |
Not enough info but if just for music and with small full ranges them with some careful placement they would sound pretty good. spec wise anyway... but if money permits i would go with the L26ROY and maybe add another later...
#3 |
Rather than sealed, you might want to put them in a half-wave pipe! It will control excursion and extend response a bit while sounding nice.
At least if i'm thinking of the correct driver. |
#4 | |
I liked the thought of two L26RFX's also due to being able to run both off a single plate amp. For the ROY, I'd need an additional amp, or 4 driver in total(parallel+series). Sounds fun, but I wish I had enough space. Multiple, smallish cabinets would work much better in this room.
#5 | |
b |
#6 |
A 9.5' tall enclosure, no thanks!
#7 |
that is why you fold
#8 |
You've caught my interest. How would I calculate a folded horn that is 11.5" wide and 15" deep externally, and meet the parameters needed as far as internal chambers/runs and height?
#9 |
Or at least point me in the right direction.
| SEAS Prestige 2.5 way | Boris_valkov | Multi-Way | 4 | 6th February 2011 05:27 AM |
| SEAS Prestige 27TFFC | bongolijus | Swap Meet | 4 | 14th June 2010 07:05 AM |
| SEAS 10" woofers H1305 (CA26RFX) or H1209 (L26RFX/P) OR ....? | Francec | Multi-Way | 11 | 24th December 2009 04:18 AM |
| Tweeter for SEAS W15CY001 and L26RFX/P | novec | Multi-Way | 6 | 16th October 2008 11:30 AM |
| Seas L26RFX/P (H1209) encosure... | CBC | Multi-Way | 1 | 7th April 2005 12:00 AM |
| Page generated in 0.13845 seconds (59.67% PHP - 40.33% MySQL) with 11 queries |
