I can not fit the script in autocad
errors "pline" not found point problems .... how to enter the script 0. |
#2 |
if you don't find it in the menus, just type _script in the command window and press enter. This should fire up the "select script file" dialog.
#3 |
non english post removed by moderation
#4 |
pline command not found
missing the point of origin I'll try again |
#5 |
make sure that there is an underscore like _pline
This will tell Autocad to use the international command, not the localised version (for example plinie for the german version). Make also sure to set _snap, _grid and _ortho to off to avoid undesired results. |
| Tractrix horn. | DonB | Full Range | 2 | 9th May 2010 03:41 AM |
| Tractrix | jphaggar | Full Range | 11 | 18th January 2009 02:16 AM |
| Tractrix Getting it right | David R. Carlso | Multi-Way | 8 | 9th July 2007 08:15 AM |
| Tractrix horn | AuroraB | Multi-Way | 12 | 8th September 2003 08:48 AM |
| Page generated in 0.30498 seconds (20.56% PHP - 79.44% MySQL) with 10 queries |
