sub enclosure design help, from india
Old 4th March 2011, 09:01 AM   #11
AllenB is offline AllenB  Australia
fs, Qts and Vas. Poor efficiency? No. Closed boxes are fine unless you're thinking about horns?
Old 4th March 2011, 09:54 AM   #12
sudhir kumar is offline sudhir kumar  India
I have read that for the same spl closed boxes require more watts.
Old 4th March 2011, 10:44 AM   #13
You won't notice it.
Old 4th March 2011, 10:47 AM   #14
Please give some more knowledge/explanation about this.
Old 4th March 2011, 11:55 AM   #15
When I build a vented midwoofer enclosure, I can block the port and only the bass will change. I have read about up to 3dB of efficiency. Whatever the reason for this, 3dB is not enough to lose sleep over, in my opinion.
Old 4th March 2011, 06:15 PM   #16
ravslanka is offline ravslanka  India
dear sudhir,
what drivers are they.are they car subs.please measure their ts parameters.
after that we can discuss the design if not what is their coil size and magnet size
there's no universal box.size of box mostly depends on vas.
regards
ravs
be a vegeterian.....
Old 5th March 2011, 08:49 AM   #17
rafeekge is offline rafeekge
Default 12" sub woofer with amp
Hello Sudhier Kumar,
If u need good quality Hand made subwoofer bult in amp u can call this number 9747370909 Mr Jamshid calicut Kerala
Old 6th March 2011, 07:31 AM   #18
Originally Posted by ravslanka View Post
dear sudhir,
regards
ravs
These are for professional use.I am trying to measure TS parameters.I will inform you about magnet size & coil size.
Old 14th November 2012, 09:45 AM   #19
sam1734 is offline sam1734  India
sam1734's Avatar
Anybody have experience of sealed vented enclosure and ported enclosure with 2 pio subs and wat is the difference between them??????
sub enclosure design help, from indiaHide this!Advertise here!
[INDIA] Any DIYer made a Gainclone in India. willing to help? smarcher Chip Amps 63 2nd January 2014 11:07 AM
enclosure design tenderland Full Range 9 23rd June 2008 08:03 PM
Enclosure design marky_sparky Full Range 8 16th August 2007 11:51 PM
Help with enclosure design Vivek Multi-Way 15 11th March 2004 05:57 AM
