#2 |
What are the specs of the enclosure?
#3 |
The dimentions are 43.75x 29.5x 24.75 h x w x d
Drivers are separated with each port being 13.75 x 5.75 x 1.5 reinforced on edges with 1". The rear deflectors are 4 61/65" wide at 45 degrees. The braces are 4" wide. at center of each chamber . I don't have a spec. sheet so that's all I can give for now micb. |
#4 |
So did you tune the ports to a specific frequency?
#5 |
"successful trial and error" I did not use any program to calc. tuning freq. but I get lows from about 35-40 hz. I xover at 60hz and eq. up around 40hz.
I use two together ,they give tight ,punchy and deep bass outdoors and kicks *** indoors!! 162805_10150124186255801_570745800_8145859_881512_n.jpg Last edited by simpleacoustic; 2nd March 2011 at 01:11 AM. |
#6 |
So what are you trying to say? Make a statement; show a design with no specifics; or just want a display gallery?
Sam |
#7 |
"show a design with no specifics"....Do the math if u like, see if its true ,was just lucky it worked out well and wanted to share,is that illegal?I was not looking at the forum rules ,sorry!!
#8 |
That's fine. Perhaps, you would like to hang around and learn how to use freely available software to simulate more predictable/repeatable builds.
Sam |
#9 |
I've just started looking at horn response ,and winisd but I did not plug in this design yet .Still need to understand it some more.
It's not as simple as I thought. Last edited by simpleacoustic; 2nd March 2011 at 08:17 PM. |
#10 |
A short guide to using WinISD PRO, Get the Thiele-Small specs for your drivers, fire up WinISD pro, put it in half screen (left side of screen) click on the help menu at the top of the window, click "getting started", expand "using winISD pro", click on "entering new driver data", scroll down about half way to "The suggested procedure for entering driver parameters is following", follow instructions. have fun
| Three way dual chamber reflex | flyingtele | Multi-Way | 3 | 30th September 2010 12:26 PM |
| Front & rear end DUAL Back Loaded Horn + Bass Reflex Hybrid Enclosure | nickthevoice | Multi-Way | 13 | 19th May 2009 03:09 PM |
| combining 18/18 watt amp and a bose acoustimass bass in a car | TwinEdge | Car Audio | 3 | 19th June 2007 01:37 AM |
| Dual Chamber Reflex Subwoofer Revisited | Hezz | Subwoofers | 14 | 26th February 2006 02:24 AM |
| bass reflex? | GAK | Multi-Way | 2 | 23rd October 2001 03:04 AM |
| Page generated in 0.14684 seconds (61.27% PHP - 38.73% MySQL) with 11 queries |
