Old 27th February 2011, 03:04 PM   #1
Default System need make over asking for help
Hello, i am new here. i have four selenium 15sws800 i want to put in two double bass horn box. freq range 30hz to 300hz. hornresp file below.
215 sele.txt
Old 27th February 2011, 03:16 PM   #2
This is the design i have i mind
Old 27th February 2011, 08:42 PM   #3
Can someone help me with this hornresp file below.
sel215.txt
Old 28th February 2011, 12:03 AM   #4
Speakerholic
Cal Weldon's Avatar
Can't open the file but with an Fs of 37 Hz and an Xmax of 6.5mm you have a hard time getting 30 Hz in that horn. Also trying the go as high as 300 might be stretch also. Just a guess though. Are there going to be removable panels so you can replace the drivers in case of an accident?
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 28th February 2011, 12:16 AM   #5
What is the lowest this speaker can play in a bass horn, also if 300hz is too high how about stopping at 150hz.
Old 28th February 2011, 01:16 AM   #6
djk is offline djk
djk's Avatar
A FLH design for 30hz is going to be huge.
I suggest you build four single TH to stack as needed. As an example of what is possible, here is a stack of two TH for some Eminence drivers. About ±2dB from 31hz~150hz.
http://i56.photobucket.com/albums/g1...h/3015LF2a.gif
Candidates for the Darwin Award should not read this author.
Old 28th February 2011, 01:34 PM   #7
[QUOTE=djk;2485624]A FLH design for 30hz is going to be huge.
How big will one of the TH be.
T
Small HTIB System/Computer System Review form109 Multi-Way 0 19th November 2009 02:59 AM
Newbie : Does this system make sense TJL, GC etc. jacklelad Multi-Way 1 11th August 2005 06:07 PM
How do I make a system where I can rattle windows at resturants? Carl BJR Subwoofers 11 3rd May 2005 06:15 AM
How make make a microchip, from a program? multiplexor Everything Else 1 20th February 2004 01:24 PM
Page generated in 0.10768 seconds (64.73% PHP - 35.27% MySQL) with 11 queries
