Old 25th February 2011, 07:41 AM   #1
Boscoe is offline Boscoe  United Kingdom
Default What sort of parameters am I looking for for a small rear loaded horn?
I know it's to do with MMS and QMS but what are good values to make a compact rear loaded horn and what are the ideal values? Is there any other values that need to be taken into account?
I thought about it once, but then thought again.
Old 28th February 2011, 08:30 PM   #2
Hi Boscoe, are you trying to design a BLH with handwritten formulas ? If so then hornresp is useful for this type of horn but you need to know quite a few more input parameters than those two. Sorry I can't give you the right answer to your question, I gave up trying to design horns by pencil and paper when I learned hornresp.
JEREMY M_________________________________
I like it loud, BUT NOT TOO LOUD!.... Hey do you hear that high pitched ringing sound ?
Old 3rd March 2011, 02:55 PM   #3
I've never been able to get hornresp to download and install properly. I would love to give it a try.
Old 4th March 2011, 10:22 PM   #4
Are you PC or mac? If PC press download ,unzip to folder of choice(have you downloaded WinZip extractor yet?), find that folder , and create a shortcut to desktop screen.
Or is it your antivirus program that screws it up?
Old 5th March 2011, 04:00 PM   #5
hm is offline hm  Europe
hm's Avatar
Hello Bascoe,
may be my HP would help, to see and imagination,
my reduced formula you can use by a simple calculator:
Calculation of expo horns
If you have AH, AM, l,
k still lacks the flare rate:
ln (AM / AH) / l = k
so you can see the surface
each point out (Al):
INV ln (l * k) * AH = Al
l m, AH + AM + AL in square meters
By Al e.g. m in width and divide
you have the distance in meters
AH = Horn throat
AM = Horn mouth
k = flare rate
l = length
Lengths and flare rate VALUES
K VALUES:
0.37 ~ 10 Hz
0.55 ~ 15 Hz
0.7 ~ 19 Hz
0.9 ~ 25 Hz
1.1 ~ 30 Hz
1.3 ~ 35 Hz
1.48 ~ 40 Hz
About an octave above k plays the horn,
if the length matches. At BL horn lengths
over 3.4 m, you get a suck out
below 100 Hz
4/lamda lengths VALUES
3.4 m ~ 25 Hz
2.8 m ~ 30 Hz
2.4 m ~ 35 Hz
2.1 m ~ 40 Hz
1.7 m ~ 50 Hz
1.4 m ~ 60 Hz
Most of my horns open
the last~ 75 cm (look ALPHORN)
with a double or triple k,
to get a better mouth+room
crossover.
http://www.hm-moreart.de
Pimping your rear-loaded horn. milesian Full Range 7 16th February 2011 08:14 PM
Can you tell me anything about this rear loaded horn I bought? Doug_Dornbos Multi-Way 0 23rd August 2007 03:25 AM
rear loaded horn farriswheel Car Audio 2 27th July 2007 05:03 AM
Rear Loaded Horn David R. Carlso Full Range 3 9th January 2006 10:04 PM
rear loaded horn question zobsky Multi-Way 5 21st September 2004 08:13 PM
Page generated in 0.10262 seconds (62.75% PHP - 37.25% MySQL) with 10 queries
