Old 24th February 2011, 04:57 PM   #1
Default Running two different subs?
What problems occur when operating two separate BR subwoofers other than peaks at overlap. One box is tuned to 48hz the other at 55hz.
I am shooting for a nice 60hz bump.
Old 26th February 2011, 02:08 AM   #2
AllenB is offline AllenB  Australia
I don't see a problem with them in general. Room modes will probably outweigh your plan for a hump, (or help you create one or even extend the bass a little).
Old 27th February 2011, 12:41 AM   #3
Hmmm how come I've read posts that claim up to -5 db difference when using two different subs? Not that I'm disagreeing with you because I've never run two different subs on the same system. It would make sense that the sum would be additive though.
JEREMY M_________________________________
I like it loud, BUT NOT TOO LOUD!.... Hey do you hear that high pitched ringing sound ?
Old 27th February 2011, 01:43 AM   #4
Room modes.
Perhaps if you imagine your room as a minefield of hot/cold spots. Where you place your sub and where you listen will each have an effect on the response. Unless you listen in a corner and put your sub in another corner, you'll have an issue. Some bass will be boosted and some won't couple well to your listening position.
Putting a second sub somewhere makes the interaction more complex, but has the potential to improve the total bass transfer to your listening position. Where and how is important.
Old 27th February 2011, 02:59 PM   #5
The different tunings will result in different phase response, so they will not have a + 6 dB summation.
This will result in uneven response across the room, LF comb filtering in addition to room problems.
I'd suggest stacking the subs to minimize the problem. A differing time delay and EQ for each box would be deeded to correct the phase difference.
The 55 Fb box will need a 7 Hz higher HP than the 48Hz box to keep from tearing up the cone, which further changes the phase response, unless you HP both at around 50Hz, in which case you loose the extension the 48 Hz box would give.
Have fun!
Old 27th February 2011, 08:18 PM   #6
revboden's Avatar
Well there's no way to tell until you try it. Phase weirdness will probably rear its head so distance tuning (moving them closer/farther apart) will be necessary. Stacking might work to couple the subs a bit but then you'r stuck with source phase cancellation (i'd spread them out). I say give it a go and see what happens.
anyone running RE subs? skooter Car Audio 6 23rd November 2008 04:35 PM
What advantages running ported midbass if you are running a sub? mitchyz250f Multi-Way 3 20th May 2008 02:34 PM
Convert floor standers to subs with Tang Band 8" subs? prerunnerv6 Subwoofers 3 26th February 2006 12:44 AM
2 subs one box/2 subs 2 boxes vetkilr Subwoofers 5 22nd February 2006 09:27 PM
p3a up and running :) Jean Solid State 10 1st December 2002 02:07 AM
Page generated in 0.10620 seconds (65.27% PHP - 34.73% MySQL) with 10 queries
