Old 24th February 2011, 04:11 AM   #1
Default Benefits of going to a sealed 12"?
A few years ago I built a wacky clamshell isobaric design with a pair of 8" SEAS woofers I had lying around. It's a fairly big box with a 4" wide port, qualifying as, I guess, something close to an extended bass shelf design. Small room, mated to some 8" Paradigm 2-ways, and it sounds pretty good for music and home theater, though perhaps suffers a bit from one-note bass syndrome. Besides cosmetics, is there any musical benefit to building a new box around a Dayton 12" classic? Would I lose something in home theater performance? would I notice a big improvement in depth, attack, etc.? I like the Dayton classic 12" as it models well in a reasonably-sized sealed box and doesn't cost too much.
GhettoSQ
Somewhere between Craft and Kraft
Old 24th February 2011, 04:18 AM   #2
tinitus is offline tinitus  Europe
Dayton Classic, short Xmax, cheap as ....
I doubt its up to the quality of your Seas
or do you mean Dayton Audio Classic Subwoofer
Old 24th February 2011, 07:46 AM   #3
chris661's Avatar
Try tuning your port lower first - if your cabinet is large and you've not dropped the tuning far enough, you will end up with a peaky response.
You can either extend the port's length, or reduce some of its cross-sectional area. Some trial and error may be required.
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 24th February 2011, 01:25 PM   #4
It's this one here:
Dayton Audio DCS305-4 12" Classic Subwoofer 4 Ohm
GhettoSQ
Old 24th February 2011, 02:00 PM   #5
tb46 is offline tb46  United States
Default Dayton DCS305-4 12"
Hi GhettoSQ,
Try a vented (BR) box with 100 L_net, and a 4"I.D. duct @ 16" long. Then you can play with changing duct length, and stuffing the duct.
Oliver
Driver Options for Sealed 12" Doppler9000 Subwoofers 3 11th April 2010 05:13 PM
12" sealed 2 way jwhit67 Multi-Way 11 11th February 2008 04:42 PM
Should I Try A DIY 12 or 15" Sealed Design?? Fore Subwoofers 34 12th September 2007 01:37 AM
Which 12" sub for sealed box rca9449 Subwoofers 1 10th September 2007 09:26 AM
Better 12" Driver for this sealed sub? birdwizard Subwoofers 12 16th September 2005 05:58 PM
Page generated in 0.08779 seconds (65.16% PHP - 34.84% MySQL) with 10 queries
