Old 22nd February 2011, 12:11 PM   #1
Chaps is offline Chaps  Denmark
Default Tapped horn .. Polarity?
Hi ..
Have a quick question for you guys.
I'm building tapped horns at the moment, while a friend of mine are building som hybrids .. He's drivers have to be wired in reverse polarity, if he mounts the driver, with the magnet facing out (like a tapped horn).
Do i have to reverse the polarity on my drivers in a tapped horn as well?
Old 22nd February 2011, 01:00 PM   #2
You can mess with the phase later on when positioning the sub in your room and integrating it with the main speakers.
Old 22nd February 2011, 01:48 PM   #3
They are PA speakers, so i was looking for more of a "generel" answer :-) .. Like reflex boxes normally are wired + to + and - to - ..
Old 22nd February 2011, 01:53 PM   #4
Originally Posted by Chaps View Post
Hi ..
DSL's convention for their tapped horns is positive voltage to the positive terminal makes the cone go inward.
Reversing the polarity may get the TH close to a phase match without applied delay to the top cabinets if the path length of the TH happens to be around a wavelength of the crossover frequency.
Tapped horns have a different phase response than FLH, BR, or sealed alignments.
Properly aligning a sub to a top cabinet needs to consider both the top cabinet and sub's phase response at the crossover point, as well as below.
Old 22nd February 2011, 01:54 PM   #5
tb46 is offline tb46  United States
Hi Chaps,
There is no easy rule of thumb, I'll attach the Hornresp phase response for two different THs both with 15" PA drivers:
Oliver
Old 22nd February 2011, 02:58 PM   #6
soho54 is offline soho54  United States
You want the driver at the throat to move into the throat when a positive battery pole is hooked up.
Done and done. Then you use Delay to match up the propagation delay induced phase variance.
Tapped Horn Feeding A Unity Horn Patrick Bateman Multi-Way 20 4th September 2010 01:27 PM
Can a Tapped Horn have a negative taper within the horn path? BP1Fanatic Subwoofers 6 13th February 2010 06:04 AM
Lab 12 Tapped Horn, Ron's Austin II, T-Horn, CNC Photo Background layertone Subwoofers 15 23rd January 2010 05:12 AM
Ron's Austin II, old T-Horn, Lab12 Tapped horn, CNC Photo Background layertone Full Range 2 23rd December 2009 12:51 AM
Help with a tapped horn. mike james 533 Subwoofers 32 11th November 2009 02:34 AM
Page generated in 0.41188 seconds (20.78% PHP - 79.22% MySQL) with 11 queries
