Old 20th February 2011, 03:19 AM   #1
tobiazz is offline tobiazz  Denmark
Default Plan request: A Traped horn to go from 35(ish)-120 w/RCF L18P200
Hey Guys
I have 2 of the RCF L18P200-N drives laying around and i would like to build a traped horn to put them in, if its posible to get one cap to go from 35hz(ish) to 120hz and around a 100-101db spl minimum in the bandpas it would be soooo sweed!
They have good power handling (800w AES) and a large xmax (9,8mm) and i can get 2 more pretty cheap
Is this posible ? is there a designe that will do this or am i looking at making a new designe?
Cheers Toby
(sorry for my bad english)
Same post on speakerplans.com...
Old 20th February 2011, 06:13 AM   #2
OscarS is offline OscarS  United States
stock sensitivity is 96 db/1W/1m. A 5-dB increase won't happen while staying reasonably flat from 35ish all the way to 120 in a tapped horn. You want an increase in sensitivity, FLH in groups of 4 is the way to go. But you won't get down to 35Hz unless you use a massive horn length. Hoffman's Iron Law. It would be nice if we all could simply specify the -3dB corner frequency AND an arbitrary sensitivity and have the laws of physics conform around us.
Old 20th February 2011, 07:38 AM   #3
With the right 96 dB speaker a TH can do 101 dB one watt one meter at 35 Hz and around 104 dB at 120 Hz.
The DSL TH-118 does, at 40 x 22.5 x 28 inches is not particularly massive.
A quarter wave length of the FC in a TH design does not require a huge mouth, so can be folded in to a relatively small enclosure.
Old 20th February 2011, 09:33 AM   #4
djk is offline djk
djk's Avatar
There may be a better solution, but here is one (5mH inductor added):
RCF - L18P200-N
Candidates for the Darwin Award should not read this author.
Old 20th February 2011, 02:29 PM   #5
Well I feel dumb. Really. I had been used to modeling using only 2V input in Horn Resp due to me simulating some "mobile audio" speakers recently. Let me see what a correct 2.83V input shows now.
Old 20th February 2011, 09:00 PM   #6
The less the Re of a speaker, the louder it will show in Hornresp.
Some "4 ohm" speakers really are more like 3 ohms.
Most amps do not quite double the power at 1/2 the impedance, so a four ohm speaker may not actually play 3 dB louder than an 8 ohm.
Old 22nd February 2011, 12:49 AM   #7
Djk what design is that?
Also on speakerplans.com i have been sugestet the cyclobs (CB-18) you thing that the l18p200 will work on fullpower 800w in that one?
I know that the sens is low at 96db/1w but it should bee posiblel i think
Old 22nd February 2011, 08:17 AM   #8
djk is offline djk
djk's Avatar
"Djk what design is that?"
That is a design I did for an 18 Sound woofer that I modified slightly for your RCF driver.
"Also on speakerplans.com i have been sugestet the cyclobs (CB-18) you thing that the l18p200 will work on fullpower 800w in that one?"
I think it should work OK, you notice that I was the one that suggested the Cyclops over there (I'm _djk_ over there).
"I know that the sens is low at 96db/1w but it should bee posiblel i think"
It looks like the TH adds about 5dB, so it should do what you need it to. The AkAbak script I posted is of one TH, a pair would smooth out a bit. Here is one, two, and four or a 40hz 15" design just to show how things change.
Old 22nd February 2011, 06:27 PM   #9
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
FYI,
Alternative designs using the RCF L18P200-N driver:
b
Old 22nd February 2011, 07:58 PM   #10
djk sorry did not notis that you were on speakerplans ;P
The grafs you are showing is that your design or the cyclobs?
Also du you have the plans for that design of yours?
bjorno how dos that design look? it seems to run out of xmax to soon?
15" tapped horn with RCF wood1y Subwoofers 113 24th April 2011 01:03 AM
Page generated in 0.17945 seconds (53.99% PHP - 46.01% MySQL) with 11 queries
