Just swapping out my Peavey Black Widows - 1888HP BWX - for some more powerful AE TD18H drivers. Swapping to the AEs as they will go better into the midrange.
So now I have a pair of 1888HP BWX to turn into subs. T/S parameters as below: ================================================== =========================== | SPLo= 96.39 dB | SPLi= 95.24 dB | SPLi= 96.65 dB| TSL File Name:PV_BW_18 | üo= 2.74 % | üi= 2.10 % | @ Eg= 2.83 V | Name : 96000057 BW 1888HP BWX Rem= 6.32 ê, Lem= 2.073 mH @ 1KHz Model: Speaker- Woofer/ Midrange Rem= 57.68 ê, Lem= 0.724 mH @ 20KHz ================================================== =========================== Znom= 8.000 ê Sd= 0.1178 sqM Fi= 33.840 Hz Hvc= 20.7000 mM Revc= 5.790 ê BL= 23.8283 TM Fo= 36.130 Hz Hag= 7.0000 mM Krm= 9.948 mê Vas= 230.1325 Litr Qms= 10.947 Xmx= 6.8500 mM Kxm= 44.661 mH Cms= 116.7856 uM/N Qes= 0.385 Cmx= 2.0000 mM Erm= 0.738 Mms= 166.1560 Gram Qts= 0.372 Cmo= 5.0000 Exm= 0.649 Mmd= 142.9080 Gram Pmx=1000.000 Wrms évc= 0.2500 C/W ================================================== =========================== The frequency range I am looking to cover is 80Hz down to 30hz or lower. I keep seeing these PPSL woofer boxes but I am not really sure how to model them. Also interested in 6th order bandpass. My preference is to use both drivers in the same cabinet. However, foot print needs to be about 500 x 550 x 1000mm (WxDxH). Is there a design I can use to achieve this? The drivers are only 140mm deep. Appreciate your suggestions |
| Low noise, low microphony, low hum valves | MarcelvdG | Tubes / Valves | 28 | 31st December 2010 09:41 AM |
| preamp supply LOW power LOW noise LOW cost | drdagor | Power Supplies | 1 | 13th September 2010 11:39 PM |
| Value of output caps for Aikido - how low is too low? | cbutterworth | Tubes / Valves | 9 | 3rd September 2007 01:34 AM |
| Extremely low power and low loss transformers | percy | Tubes / Valves | 12 | 23rd February 2005 10:30 AM |
| Page generated in 0.06756 seconds (68.13% PHP - 31.87% MySQL) with 10 queries |
