I tripped over the cable to my husband's B&W subwoofer and broke the pin on the unit. Can this be replaced DIY? Are there reputable repair shops in the Buffalo, NY area? HELP!
#2 |
frugal-phile(tm)
Hi Joy,
Can you post a picture? We are likely talking about an RCA connector (on the sub, or on the cable?) or possibly high level speaker connectors. Anyone competent with a screwdriver & soldering iron should be able to fix it, as long as no other damage occurred (if the amp was on the possibility of damage from disconnection of an RCA can cause a transient that can cause damage, in most cases the possibility is probaby slight) dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
frugal-phile(tm)
More: B&W have a dealer locator on their website.
It shows at least 3 in Buffalo (there are 4 dealer types to search on), and more in Rochester. dave
#4 |
I pull the board with the RCA male connect, they used an gob of expocy to attach it It white and very hard , i don't think i can remove the expoxcy without damaging the board. Any idea's
#5 |
tell hubby to do a better job wiring next time!
#6 | |
frugal-phile(tm)
dave
| EU AMP Ecodesign Working Plan 2009-2011 - No way for new Class A - AB - H & Tube Amps | qsa | Solid State | 0 | 4th May 2010 07:47 AM |
| mosfet class a/ab amp | p robertson | Solid State | 30 | 9th February 2010 11:07 AM |
| tweaking a class AB amp | blunt | Pass Labs | 2 | 21st March 2007 09:19 PM |
| help!ab class mosfet amp | mbonus | Solid State | 31 | 19th September 2005 04:14 PM |
| J L HOOD A/AB amp | Zen Mod | Solid State | 3 | 23rd May 2004 08:51 PM |
| Page generated in 0.09800 seconds (64.04% PHP - 35.96% MySQL) with 11 queries |
