Old 17th February 2011, 04:31 AM   #1
Broovwa is offline Broovwa  Australia
Default Krix woofer power handling?
Gday guys (and the odd gal i guess)
I've got a Krix seismix 3 subwoofer that has a busted amplifier. I'm looking at replacing the amplifier with one of the hypex plate amplifiers, but dont know which one i should go for, because i really dont know the power handling of the woofer. Would anyone here have any insight into the specs of the woofers used in the Seismix line.
When manufactured, the amplifier was rated at 220W RMS and 400W max, and the woofer is 10 inch diameter.
The Hypex i would like to buy is the 400W version, but dont know if this will be safe.
Thanks for any advice.
Brad.
Old 17th February 2011, 04:44 AM   #2
The extra power of a larger amp is unlikely to be a problem. The biggest killer of speakers is too small an amp driven into clipping. This then exposes the voice coils to a square wave which has a much larger heating effect on the coil.
Further, the woofer's travel is highly likely to be exceeded prior to voice coil thermal problems. This should be clearly audible (i.e. when you turn it up so loud it sounds terrible).
So, if no problems with the money, just buy the bigger amp and don't keep driving the speaker if it hits its limits and sounds bad. That's my take on it...
power handling lsutherlin Multi-Way 1 19th October 2007 10:57 PM
Tweeter power handling ? youyoung21147 Multi-Way 29 4th May 2007 12:53 AM
Power output vs speaker power handling Bob0513 Chip Amps 4 5th November 2006 10:41 AM
power handling for resistors? tdemont Multi-Way 3 14th January 2005 01:20 PM
Power Handling Myren Multi-Way 1 30th October 2001 07:18 AM
Page generated in 0.13848 seconds (44.60% PHP - 55.40% MySQL) with 10 queries
