Possible to convert servo amp to non-servo?
Old 17th February 2011, 02:13 AM   #1
mfaughn is offline mfaughn  United States
Default Possible to convert servo amp to non-servo?
I have a Velodyne ULD-15 amp that was flood damaged. I replaced it with a totally working one. The damaged one still sort works. It works ok until it doesn't and when it doesn't it either has a significant hum or makes a loud horrible distortion...those sorts of shenanigans. I was wondering if the problem was in the feedback circuit and if it might not be possible to try it out as a regular amp...or perhaps it is nearly impossible?
Note: I obviously intend only to use it with non-servo drivers if it is possible to convert.
Old 17th February 2011, 09:48 AM   #2
bentoronto is offline bentoronto  Canada
How easy it is to convert depends on your electronic sophistication.
A motional feedback (AKA servo) amp gets feedback from the driver (in one of various possible ways of doing so) rather than from a plain old resistor. Simple as could be change back to a plain old resistor... if you understand what to do. Also, possible the amp will run perfectly well without the external feedback - ask the manufacturer.
Well out of my league and I don't know anything about that amp. Some of the trouble sounds like water damage and not too specific to MF. Dunno if that amp would work properly unless you addressed the conversion question.
HiFi aspirations since 1957. Currently working on motional feedback again... the final frontier in audio; it was my personal pet project when I was a scientist at the premier Bell Labs at Murray Hill, home of the world's largest anechoic chamber
Old 17th February 2011, 11:18 AM   #3
I can measure the impedance curve across the driver and choose an appropriate resistor...if I understand what your saying. That doesn't convert the amp to non-servo though...it seems (in my relative ignorance) that it leaves the servo circuitry in place but just keeps the driver from being responsible for loading it. I think this driver uses an accelerometer(maybe?) if that helps.
Old 17th February 2011, 11:35 AM   #4
R.I.P.
In simple terms probably the open loop gain without the motional feedback
to reduce it to a more normal closed loop gain will be far too high, it will
probably hum and overload very easily.
Probably what needs adding is a normal feedback loop to reduce the gain.
rgds, sreten.
Old 17th February 2011, 02:28 PM   #5
+1
Shouldn't be hard to ask manufacturer or to eyeball the speaker connector to tell if they use a special VC winding or an accelerometer (which might have a power supply lead).
If it does use a sensor, then that isn't intimate with the amp feedback system - if you know what I mean - and so can't lead to funny noises in its absence.
All this is just guessing on my part.
Old 18th February 2011, 12:00 PM   #6
R.I.P.
Hi, mostly incorrectly IMO, rgds, sreten.
Old 18th February 2011, 02:59 PM   #7
It seems to me if your going to hand out a broad slap in the face of somebody, your really ought to be just a tiny bit specific about the issues.
Maybe just my point of view.
Old 19th September 2011, 06:28 PM   #8
R Dijk is offline R Dijk  Norway
Hi, why convert one servo system instead of finding the fault AND have two in working order? Do you plan to convert the other one as well?
R
Old 19th September 2011, 06:46 PM   #9
R
Digging up an old thread but to answer your question, I have a lot more use for a "regular" power amp than I do for having an extra amp to use with the velodyne driver. Currently I have one working ULD15 amp that pushes one ULD 18 driver...and one somewhat broken ULD15 amp that was flood damaged but still shows signs of working (but that doesn't completely). As of now I am considering just using the chassis, toroid, volume pots, and maybe caps for another project and just shelving the boards. It would cost me more to buy a new chassis for another project than I could get by trying to sell a broken amp on fleabay.
Possible to convert servo amp to non-servo?Hide this!Advertise here!
Q: removing Servo in amp jjacks4x Solid State 1 10th March 2010 09:27 PM
Velodyne Servo plate amp Kickin Wing Solid State 5 12th January 2009 03:05 AM
Servo amp schematic jlsem Analogue Source 0 9th January 2007 12:00 AM
DC servo in Amp blu_line Solid State 10 26th November 2004 03:42 PM
Copyright ©1999-2017 diyAudio
