2 18 bass design - Page 3 - diyAudio
Old 13th February 2011, 07:53 PM   #21
Thawach is offline Thawach  Thailand
Thawach's Avatar
haha is a little bit of lol, your thread made me laugh after i posted and before i went to sleep. neo dan post is okay. not too low with manifold v front he tuned about 47 hz. and if u don't like i think turbo charge box is the best way.
Product | TSW-218 | Turbosound
Old 13th February 2011, 07:55 PM   #22
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
18SW2P by Dan - Google 3D Warehouse
Dan
Old 13th February 2011, 07:56 PM   #23
NEO Dan's Avatar
It is as the OP drew it up.
Dan
Old 13th February 2011, 07:57 PM   #24
Thawach's Avatar
last week i posted manifold but likes planar front. the pic is this.
Thanks: ฝากรูป
Old 13th February 2011, 08:01 PM   #25
djk is offline djk
djk's Avatar
Well it doesn't load, whatever it is, and it has a .zip suffix.
http://image.free.in.th/z/iz/frontof...ermanifold.gif
This does nothing either.
The Turbosound box is over 50% larger, and we don't know if his drivers will work either. I don't believe their specs for 4dB to 35hz either, not for one box anyway. It's rated at 104dB/W/1M and -4dB at 35hz (which I don't believe for a single), the dual 18SW2P box is 104.8dB/2.83V/1M according to BB v6.0, and -3dB at 42hz in singles. A vented box will always eat a horn of similar size, until the horn exceeds the size where the direct radiator has reached about 25% efficiency. A tapped horn is not really a horn or a vented box, and falls somewhere between the two.
"Is this much higher than the eaw 850 ?"
Yes, it's tuned to 40hz, and requires less EQ than the EAW does in that region, the EAW looks to be tuned to around 30hz and has a bunch of EQ to make it down there (nothing wrong with that if you have the power, and the drivers will handle it).
Candidates for the Darwin Award should not read this author.
Old 13th February 2011, 08:08 PM   #26
NEO Dan's Avatar
It's ok as a cluster of 4
Dan
Old 13th February 2011, 08:10 PM   #27
NEO Dan's Avatar
LOL
Just follow the download link
Dan
Old 13th February 2011, 08:17 PM   #28
NEO Dan's Avatar
Google SketchUp
Dan
Old 13th February 2011, 08:21 PM   #29
Thanks ,I still like the v-front since its easier to access the drivers if needed.
4 of these at that frequency range for outdoor use should be good for reggae ,soca and pop no? The tsw 218 looks good ,any plans?
Old 13th February 2011, 08:25 PM   #30
Thawach's Avatar
Originally Posted by NEO Dan View Post
dan i started to use it a few weeks but never save it. don't kwow about the skp extension name. sometime i will change planar to hyperbolic.
Ciare 18 bass horn design soundhead Subwoofers 6 23rd September 2015 12:32 AM
combining 18/18 watt amp and a bose acoustimass bass in a car TwinEdge Car Audio 3 19th June 2007 02:37 AM
Zaph L 18 with two bass drivers? buckpider Multi-Way 0 14th October 2005 07:31 AM
Best bass out of Beyma 18 p1000 ??? slacker0001 Multi-Way 1 13th July 2005 04:38 PM
18" Folded Bass Horn Design djdan Multi-Way 11 27th October 2003 10:21 AM
Copyright 1999-2017 diyAudio
