I want to build 4 new basrefleks subwoofers
I already have 16 Peerless XLS 830452 units from another projekt. didn't really get into the hole Dipole thing... I'm going to build 4 cabs of 200 liters(minus the ports) each with 4 speaker units. But i was wondering if i would be better of using a pro woofer instead. using a pro woofer instead has both pros and cons.. Both setup would almost have the same powerhandeling(more than i can throw at it anyways..) Pros a little higher SPL above 30hz Cheaper(depends) Cons Lower Xmax It can be cheaper to buy a pro woofer, if i get a good price on my Peerless XLS unit. What would YOU do? if you would buy a pro driver, what driver would you buy. I've looked at PD, Beyma and Fane |
#2 |
I would use the Peerless woofers. They are made for exactly what you are planning.
Is this going to be used in a disco or something? I can't imagine what 8 woofers like those would do in a home situation...
Pass Labs Pearl Phono -- Pass B1 Preamp -- Pass F5 amplifier -- Pass Labs Pearl 2 |
#3 |
It's for my home theater.
Forgot to mention that i am going for the the lowest hz possible |
#4 |
With a Para-EQ and pro-amplifier It should do some damage.
Pro drivers like big boxes to get really low but then you don't need much amp. |
#5 |
For home theater? Wow. It will shake the entire house!
With a woofer array like that, once you add the room gain you will have an amazing woofer! Also, the bulk of the bass energy in a movie soundtrack is in the 50-100hz range. Really deep, low response is not as important as you might think.
#6 | |
#7 |
Can i conclude that you all think i should keep the drivers?
#8 |
With 16 Peerless XLS 830452 I'd look at putting 4 sets of 4 drivers in an IB configuration in 4 locations in your room.....if that is posible. Their low Qts will give you very fast bass.
#9 |
#10 |
| Transformers: How big is TO big?? | dfdye | Power Supplies | 39 | 4th September 2010 02:30 PM |
| Big Toroids & Big Caps | K-amps | Swap Meet | 10 | 25th June 2009 07:43 PM |
| Having problems with port size... how big is far too big? | fjhuerta | Multi-Way | 10 | 30th August 2005 06:20 PM |
| Big Big hum ??? | vlljpior | Tubes / Valves | 4 | 26th August 2005 03:53 AM |
| Page generated in 0.15299 seconds (61.19% PHP - 38.81% MySQL) with 10 queries |
