How does the BeoLab5 room correction work?
Old 6th February 2011, 07:14 PM   #1
boris81 is offline boris81  United States
Default How does the BeoLab5 room correction work?
Sound - Bang & Olufsen
The BeoLab5 loudspeaker claims to have a feature that equalizes the bass to correct for room interaction. From The Audio Critic:
"The Adaptive Bass Control works as follows. You press the center of the top circular disk on the speaker. A tiny microphone snakes out from underneath the subwoofer. A sequence of tone bursts begins. When itís over, the microphone changes its position by a short distance. A second sequence of tone bursts follows. When itís over, the microphone retracts. (Showmanship reinforcing technology!) From the two readings, the onboard computer calculates the low-frequency equalization required for flat room response at that particular location and applies the calculated curve. Flashing red and green pilot lights monitor the entire sequence. Then you repeat the same process with the other speaker. Thus, no matter where the speakers are located, you can have totally optimized in-room bass response. No additional instrumentation needed. The difference in low-frequency smoothness before and after the procedure has to be heard to be believed. Most rooms are terrible bass messer-uppers. "
Does anyone know how exactly they accomplish the room correction? The Bang and Olufsen website talks about 3 preset bass correction curves corresponding to the distance of the speaker to a wall or corner. Do they simply pick the best preset curve or is there more to this? Has anyone heard the BeoLab5 and what is your impression of it?
How does the BeoLab5 room correction work?Hide this!Advertise here!
Digital Room Correction Project boconnor PC Based 54 4th November 2011 09:22 AM
Is a Room correction trial possible? brianuk PC Based 7 5th October 2009 08:29 PM
I need help with digital Room-correction Radian Multi-Way 1 7th February 2007 08:10 PM
Room correction systems herodote Digital Source 0 24th July 2006 11:56 AM
TACT room correction information ctviggen Digital Source 0 30th November 2005 08:46 PM
Copyright ©1999-2017 diyAudio
