Old 5th February 2011, 09:00 AM   #1
chusso is offline chusso  Serbia
Default Push-pull subwoofers with two drivers
Anyone has tryed to make it?? any good suggestions??
2x4ohm drivers in serial was my idea!!
Thanks a lot
Alex
Old 5th February 2011, 01:26 PM   #2
djk is offline djk
djk's Avatar
Search PPSL, djk
http://i56.photobucket.com/albums/g1...CoePA-2009.jpg
M&K did a common back volume with the drivers on adjacent sides of the box, it got distortion cancellation, but only in the bottom octave.
http://t3.gstatic.com/images?q=tbn:A...KbyW2DtXz8&t=1
Old Audio Pro Ace bass from the late 70s:
http://t1.gstatic.com/images?q=tbn:A...jLIBPiNCUg&t=1
Candidates for the Darwin Award should not read this author.
Old 5th February 2011, 01:47 PM   #3
kach22i is offline kach22i  United States
kach22i's Avatar
Thanks a lot
Alex
For years I planned making (2) 6 inch diameter x 6 foot PVC or stiff cardboard tube bass cannons using 4 inch Radio Shack woofers I've had for 20 years. At one end the driver basket would be inside the tube, the other side the driver basket would be facing outside (wired out of phase).
Never built it, but think there has since been products or kits designed to be positioned behind a couch or hung by wires overhead. I think Bose even makes something like that now.
System Services, Inc. Las Vegas * Nevada (702) 493 - 1163
I purchased a M&K MX-90 push pull subwoofer back in 1994 and still use it. It is a sound design and I've always liked the concept as well as the sound.
Martin Logan / now Paradigm subwoofer uses an interesting layout too.
Martin Logan Descent i & Depth i Subs - Home Theater Forum and Systems - HomeTheaterShack.com
Tubes and Martin Logan's
Old 8th February 2011, 06:18 AM   #4
Thanks a lot
Alex
What is your goal? Where will these be used? Home theater? Live sound? What amp? How big? What frequencies are you trying to reproduce?
Justin
Old 8th February 2011, 06:37 AM   #5
picowallspeaker's Avatar
Don't know if 'serializing' two drivers instead of 'paralleling' them might be worse . If they are also mechanically cross-connected ,like in isobaric p-p ,currents in the VCs would be also 'equalized' due to backEMF and mutual pistonic movement . If the two VCs are not perfectly equal ,one speaker may have slightly different 'activation' time ,so it may be a 'load' for the more efficient one. Am I clear ???
Old 8th February 2011, 07:07 AM   #6
frugal-phile(tm)
planet10's Avatar
For the sake of novelty they miss getting the most force cancellation. They are relying on the cabinets to act as force carriers which means the box is taking all the load, and by having 3 instead of 2 or 4 are not using the most effective geometry.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 10th February 2011, 10:21 PM   #7
revboden's Avatar
This may be a bit obvious... Steve's Compounded, Super-Duper Shiva/Sonotube(R) T-line Subwoofers
Loudspeaker drivers in push-pull StigErik Multi-Way 3 24th March 2010 12:08 PM
Push-Pull drivers for array? ted4412wilt Multi-Way 1 26th January 2009 03:27 PM
Building push-pull subwoofers Klook Subwoofers 50 23rd March 2008 09:37 PM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 3rd November 2005 11:25 PM
Parallel Push Pull Drivers gingertube Tubes / Valves 14 13th May 2005 01:32 PM
Page generated in 0.10276 seconds (76.03% PHP - 23.97% MySQL) with 10 queries
