Old 2nd February 2011, 01:32 AM   #1
jmillerdoc's Avatar
Default Titanic MK3 in OB H frame?
Wondering what it would take, if possible, to build an OB for the Titanic MK3. I have another thread recently posted about this driver and an 1000w plate amp for a boxed enclosure...was soliciting advice. Since that was posted I had the chance to listen to an awesome OB sub and was hooked. Wondering if I could get similar, satisfactory results using the same Titanic and plate amp. The amp is essentially the same as the PE one with the Parametric EQ and such.
I've heard high Qts drivers are best for this but I have also read another authors thread about using a sub for an OB with similar Qts as the Titanic.
Thoughts, ideas, criticisms.....
Old 2nd February 2011, 11:31 AM   #2
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
See a HR H-frame template example using the Titanic MK3 driver:
b
OB H frame Emin Alpha 15A & CRH-70 - Help needed andb Multi-Way 20 5th May 2012 05:22 PM
MJK’s Jordan JX92S OB with a Goldwood GW-1858 Woofer in an H Frame Jim Shearer Full Range 606 25th April 2012 11:11 PM
MJK OB over H-Frame finished gvimhoof Multi-Way 17 31st March 2012 08:29 PM
Help with modeling Titanic MK3 15" and Dayton 1000w plate amp jmillerdoc Subwoofers 9 2nd February 2011 03:02 PM
Titanic MK3 downfiring sub Renron Subwoofers 6 27th March 2007 03:51 PM
Page generated in 0.08472 seconds (65.29% PHP - 34.71% MySQL) with 11 queries
