Old 1st February 2011, 08:49 AM   #1
Default Home Theater Subwoofer Help
Can someone please help model these two woofers for me? Can you overlap the graphs and give the specifics( max spl,max power,-3db,etc..) Thank you very much. As I am having problems with the program.
18" JBL(two of these)
V
OICE COIL DC RESISTANCE: REVC (OHMS) . . . . . . 2.50
V
OICE COIL INDUCTANCE @ 1 KHZ: LEVC (MH). . . . . . . . 0.98
D
RIVER RADIATING AREA: SD (IN2) . . . . . . . 195.99
S
D (CM2). . . . . . 1270.00
M
OTOR FORCE FACTOR: BL (TM) . . . . . . . . 13.51
C
OMPLIANCE VOLUME: VAS (FT3). . . . . . . . 15.37
V
AS (LITERS). . . . . 362.61
S
USPENSION COMPLIANCE: CMS M/N) . . . . 158.32
M
OVING M***, AIR LOAD: MMS (GRAMS) . . . . 177.77
M
OVING M***, DIAPHRAGM: MMD (GRAMS). . . . 151.75
F
REE-AIR RESONANCE: FS (HZ) . . . . . . . . 30.00
M
ECHANICAL Q: QMS. . . . . . . . . . . . 6.77
E
LECTRICAL Q: QES . . . . . . . . . . . . 0.46
T
OTAL Q: QTS . . . . . . . . . . . . 0.43
M
AGNETIC-GAP HEIGHT: HAG (IN) . . . . . . . . . 0.32
H
AG (MM) . . . . . . . . 8.13
V
OICE-COIL HEIGHT: HVC (IN) . . . . . . . . . 0.75
H
VC (MM) . . . . . . . 19.05
M
AXIMUM EXCURSION: XMAX (IN) . . . . . . . . 0.22
X
MAX (MM). . . . . . . . 5.46
S
ENSITIVITY (2.83 V @ 1 M): 95 dB
P
OWER HANDLING: 600 WRMS
15" Stillwater Designs(four of these)
Revc...6.88 ohms
Vc mH...1.33
Bl...17.114
Vas liters...415.6...cu ft...11.77
MMs grams...208.69
Fs...17hz
Qms...10.23
Qes... 0.53
Qts...0.504
Xmax...9.52mm
Pmax...750watts
Old 5th February 2011, 12:01 AM   #2
Done. 10 cf 14hz . Thanks
Home Theater Project w/ DIY In-wall 8945P speakers and IB subwoofer wigginjs Multi-Way 1 21st January 2010 07:21 PM
DIY home theater subwoofer with car audio subs! Rockworthy Car Audio 5 3rd October 2009 07:12 PM
Custom Home Theater Project in New Home, Opinions appreciated. thadman Multi-Way 5 20th November 2008 12:40 AM
Help me build a Home Theater subwoofer rocko1290 Subwoofers 3 1st September 2006 08:53 PM
Home Theater Subwoofer Myren Subwoofers 18 5th November 2001 01:04 PM
Page generated in 0.14315 seconds (69.61% PHP - 30.39% MySQL) with 11 queries
