Old 31st January 2011, 04:10 PM   #1
Decca is offline Decca  United Kingdom
Default Active Sub - connecting to amp ?
Hi all,
I'm new to the forum and have what is probably a very basic question for the experts on here. Hope you can help.
I'd like to add a sub I have spare to my stereo amp.
The sub is an active KEF Kube 1 with 2 x RCA signal inputs but no high level speaker terminal inputs or outputs.
My amp does not have a sub or RCA out sockets only inputs for a source.
Is there any way to connect the sub ?
Old 31st January 2011, 04:16 PM   #2
Did it Himself
richie00boy's Avatar
Try using a speaker to line level converter for a car stereo, or you can make something yourself using some resistors.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 31st January 2011, 04:41 PM   #3
Thanks,
Or would it work if I disconnect the amp in the sub i.e. make it passive ? Would I need x-over ?
Old 31st January 2011, 05:34 PM   #4
Did it Himself
No it would load your amp too much, only be one channel (left or right) and need a crossover. An active sub is far better.
Old 1st February 2011, 10:30 AM   #5
djk is offline djk
djk's Avatar
Posted by djk (M) on January 31, 2011 at 23:23:34
In Reply to: RE: Speaker wire to RCA subwoofer posted by Bourbon Jack on January 31, 2011 at 10:55:50
Go to Radio Shack.
Buy a pair of 1K 1/2W resistors, and a 100 ohm 1/2W resistor.
Tie one 1K to each of the L and R speaker hots, tie the other ends together and to one end of the 100 ohm, and hook the other end of the 100 ohm to one of the speaker grounds.
Take an RCA cable and hook the center conductor to the junction of the two 1K and the 100 ohm, and the shield to the other speaker ground.
The junction of the three resistors and the center conductor of the RCA cable should be soldered, I would wrap a small piece of wire around all four conductors to hold things together while soldering, then wrap a piece of tape around this junction. You shouldn't need a box if you're neat about it.
Candidates for the Darwin Award should not read this author.
Connecting 2 subs to 1 amp TTrelease Subwoofers 21 4th May 2012 08:20 PM
need help connecting pro amp to pc joka22 Solid State 23 6th July 2007 12:43 AM
Connecting Mixer,Laptop & Microphone lucknowm Digital Source 2 22nd September 2006 02:57 PM
Connecting PSU to AMP (with 9 wires) cedus Everything Else 9 4th November 2004 09:06 PM
Connecting a Ipod with car amp? tsnyder41 Solid State 3 26th May 2003 05:55 PM
Page generated in 1.34208 seconds (6.80% PHP - 93.20% MySQL) with 10 queries
