THAM10 - a 10" compact TH proposal
THAM SERIES
Hello martinsson
greetings THAM 18 working very good waiting for more drivers to
come
warm regards
Andrew;)
Does anyone happen to have Martinsson's email they could IM me. I just started a thread inquiring on the TPAM HTL and had some questions for him.
Also has anyone else built any Tham 10's? I have some Alpine type R 10" drivers I need something to do with and might just build one for music listening in my living room. The Tham just doesnt quite go low enough. I love my Tham 15 though.
THAM 10 Output? / Model
Hello - I'm also looking for some info on the THAM 10's performance. Any experienced users or modelers out there?
My goal would be to pair them with a pair of BFM SLA Pro tops - 6 x 6" a side.
I'd like to use the B&C 10CL51 (specs below), it's only 2.6# & available for a reasonable $84.
My concern is it's 150/300 watt rating. Would 2 THAM 10s run with the SLA's or would 4 or more be needed?
I've modeled the THAM in Sketchup, if any potential builders would like a file, let me know -
Fs 60 Hz
Re 5.2 ohm
Qes 0.44
Qms 3.8
Qts 0.39
Vas 31 dm3 (1.1 ft3)
Sd 320 cm2 (49.1 in2)
EtaZero 1.55 %
Xmax +- 6 mm
Xvar +- 6 mm
Mms 31.5 g
Bl 12 Txm
Le 0.8 mH
EBP 136 Hz
