Old 29th January 2011, 02:46 AM   #1
jmillerdoc's Avatar
Default Help with modeling Titanic MK3 15" and Dayton 1000w plate amp
Hello,
I recently purchased a single Titanic MK3 15" sub, Dayton 1000w plate amp with parametric EQ, and a pair of Precision Port 4" ports.
I need some help modeling the best tradeoff between size and performance in a BR enclosure. My listening room is pretty large as it spreads out into the kitchen and dining, probably half of my floorspace of a 1900sqft house.
I was looking at a few other threads and saw about 6cuft was a god tradeoff but they didn't go into porting for this size.
I was thinking about making an 18"x18"x35" external dimension box using 1.5" MDF. That should be pretty close to the volume I need, I think.
Any help with adjustments to this size and of course porting using what I have on hand would be appreciated.
Just out of curiosity, what could I expect using a 16" internal dimension sealed cube with this sub and plate amp? Could it be EQ'd enough to get the bottom end below 30hz?
Thanks for your help!
Jeff
Old 29th January 2011, 12:36 PM   #2
Hi there,
I did a quick model for you, with the dimensions you choose and wood thickness you are only getting around 4 cubic feet, not good for a ported design with this driver.
A 16" cube with 1.5" wall thickness is only 1.5 cubic feet, very small for a 15" driver, 8 cubic feet tuned to 23Hz looks pretty nice, you will need a HPF @20Hz and 3 four inch ports to keep port air speed down.
.75" walls will be ok as long as its well braced, maybe a 20" cube sealed might be a nice trade off, but i would make room for ported if i were you.
Orange is 8 cubic feet.
Grey is 4 cubic feet.
Yellow is 1.5 cubic feet.
HPF at 20Hz on both ported subs.
Old 1st February 2011, 10:17 AM   #3
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Originally Posted by jmillerdoc View Post
Hello,
I recently purchased a single Titanic MK3 15" sub, Dayton 1000w plate amp with parametric EQ,....Just out of curiosity, what could I expect using a 16" internal dimension sealed cube with this sub and plate amp? Could it be EQ'd enough to get the bottom end below 30hz?..Jeff
Hi Jeff,
A sealed enclosure would IMO be a good choice and of course a T-TQWT too.
b
Old 1st February 2011, 01:01 PM   #4
jmillerdoc's Avatar
Default Help with dimensions
Originally Posted by bjorno View Post
Hi Jeff,
b
Bjorno,
I am having a hard time reading that pic, the resolution is poor on sizing it up. Can you give me the dimensions of the TWQT as well as driver placement and anticipated stuffing? I think I read on your picture that it tunes around 19hz at Fb?
What about using this woofer in an H frame open baffle? Can it work well? I recently listen to my first OB setup a few days ago at Danny Richy's place and the bass from the OB os truly amazing.
Jeff
Old 2nd February 2011, 11:26 AM   #5
Bjorno,
Jeff
Hi Jeff,
First: Try to open the pictures in another window, click on the thumbnails,click on the lower left corner to magnify the pictures.
You can use the Titanic in a H frame OB but the possible SPL for sub frequencies would be far lower if compared.
Agree that OB-bass sounds good but compared with what?
If you play an OB speaker just below x-max and compare using the same driver in a T-TQWT equalized to copy the OB FR and levels , you will find the latter to have almost benign IMD/THD while the OB by definition would have at least 10% THD and much higher levels of IMD colorations.
You can look at the level differences in your next thread where I show a H-frame template simulation using the titanic driver.
b
b
Old 2nd February 2011, 02:11 PM   #6
jmillerdoc's Avatar
Default I think I got it
Hi Jeff,
b
b
Ok, I think I got the dimensions but wanted you to verify.....the res was still a bit low.
18"x18"x35" (internal or external with ? Thick material??)
driver centered on bottom part of enclosure with vertical center at 10"
What about stuffing and where?
Thanks,
Jeff
Old 2nd February 2011, 02:40 PM   #7
[QUOTE=jmillerdoc;2455076]
...the res was still a bit low..
? Maybe someone else can help you, I have no problem when looking at the pictures.
..18"x18"x35" (internal or external with ? Thick material??)
driver centered on bottom part of enclosure with vertical center at 10"..
The closed box external dimensions using 3/4" wood are: 18" x 18" x 35" and the driver is centered 10" from the bottom.
..What about stuffing and where?...
You need about 2lb = ~2kg stuffings(Polyfill) evenly distributed to cover the entire internal volume.
Ultimate Polyfill Subwoofer Enclosure Resource - AudioJunkies
b
Old 2nd February 2011, 02:46 PM   #8
jmillerdoc's Avatar
Thanks, perfect.....not sure why I can't get those pics to show as sharp as you, maybe it's my old failing eyes. I can see most everything but the "8's" are hard to be sure.
Anyways, thanks...that enclosure is sealed or open somewhere? Didn't see where the ports would be called for, maybe I am not looking hard enough. It's not too big and that's good, didn't want a monster of a piece of furniture the wife would fuss about.
Thanks again for your help.
Jeff
Old 2nd February 2011, 02:48 PM   #9
jmillerdoc's Avatar
Oh, I see now at the very top....closed transmission line enclosure.....
Thanks,
Jeff
Old 2nd February 2011, 03:02 PM   #10
Thanks,
Jeff
Yes, If a closed transmission line is made compact it really behaves as an ordinary closed box but when simulated you have control over the stuffings opposed to all the simpler simulation programs used here at DIYaudio.
b
Dayton Titanic MkIII 15" sub bottom out chainenoble Subwoofers 18 13th December 2010 04:59 PM
HELP- Titanic MKIII 12"+Plate Dayton 500W lascur Subwoofers 8 2nd December 2008 03:53 PM
Dual 15" Dayton Titanic MKIII Design Help chance_11 Subwoofers 25 3rd February 2006 07:46 AM
My first DIY project. The 15" Dayton Titanic MKIII. Pics perpetual Subwoofers 11 18th April 2005 03:56 AM
Enclosure for 15" Dayton Titanic ihearyou Multi-Way 3 19th December 2003 12:12 PM
Page generated in 0.14877 seconds (71.93% PHP - 28.07% MySQL) with 11 queries
