Hello,
I'm a real newbie at this site. I've been surfing around on forums to learn as much as I can to build a (Guitar) bass cabinet. The more I read the more I get confused. Any way, I am planing to build it. And I would like to ask the people with experiences to give me guidance. Here are my thougth: 1) I would use 3/4" thick Plywood 2) I will use (speaker) LEGEND CB15 - 8 Ohms, 300 Watts this LEGEND CB15 requires only 2 cubic foots closed box. Questions: 1) Could you provide me (closest) measurement of the cut-wood to build 2 cubic foots. 2) Do I have to make cross over within this box? (I don't even know that the cross over is). 3) what I need to included the cross-over in the box? |
#2 |
hi
select the Dimensions on box wizard that u want. and adjust until Internal Vb is 2 cuf Rockford Fosgate® - Woofer BoxWizard the details of bass guitar,u can read from this link. Speaker cabinets regard/
*out of the past=out of the future=in the present time+ing* Last edited by Thawach; 25th January 2011 at 01:01 AM. |
#3 |
For bass guitar you do not need a crossover unless the driver specifies. A crossover is a circuit that splits up the frequencies and sends them to different types of speakers in simple terms. There are many free calculators online that will be able to calculate the box for you.
#4 |
Hi, i played electric bass for 8 years.
The cabinet is the 80 % of sound that you want. Generally bass cabnet work in bass reflex, and have or a single 15" or more 8 - 10 " driver. I have a 15" rcf pro ( 800 w rms ) in a marine plywood cabinet ( bass reflex ) + a double piezoelectric tweeter. It Sound cold, deep and metallic, not for jazz or warm style. If u want a warm & fat sound u can use 2 or 4 8" or 10 " speaker in bass reflex enclosure ( i like eminence beta 8a 225 wrms each ).What's style of sound that u want? fatty, quick or cold ,deep .... How many power ? Plywood imho is the better material, light, strong and sound good. Mdf is to heavy and imho have a bad sound for a bass / guitar application. |
#5 | |
Speaker Detail | Eminence Speaker regarding your question if you dont know how to calculate simple box dimensions, may I ask where do the 2 cubic feet come from ? |
#6 |
I would check talkbass.com
#7 |
Hi BuildByHands,
Here is the box data you asked for (you always need to add some volume, here I added 20%, you also want to staple about 2" of fiberfill to the inside, e.g.: one side, top and back): Regards,
Oliver |
#8 |
Thank you all for your response.
#9 |
Bass guitars do not just put out low freqs. so most good bass cabs with large drivers (15") also have a tweeter. If you use smaller drivers ( 4 x 10") you might get away without the tweeter. Look at some comercial designs for ideas.
#10 |
Hi CBDB,
What is tweeter? Could you explain? How do I include it in the cabinet? |
| 2x12" bass guitar cabinet | boneless | Instruments and Amps | 27 | 18th July 2010 06:38 PM |
| Beginner - Building a bass guitar cabinet | richmoore1998 | Multi-Way | 3 | 27th December 2008 02:31 PM |
| bass guitar cabinet | babagau | Multi-Way | 6 | 2nd September 2008 11:16 AM |
| Bass guitar cabinet at kappalite3015LF | sokol | Multi-Way | 0 | 14th May 2007 07:19 PM |
| bass guitar cabinet wiring | stupid m0nkey | Multi-Way | 3 | 8th March 2004 01:15 PM |
| Page generated in 0.18362 seconds (52.47% PHP - 47.53% MySQL) with 11 queries |
