I have two drivers in my basement, and I'd like to use one or the other in a horn sub. My computer (sadly) can't run HornResp, and Akabak seems to be quite beyond me. Any suggestions?
1. Audiopulse Epic 12 DISCONTINUED Audiopulse EPD412 EPIC 12" DVC Subwoofer 4 Ohm | Parts-Express.com 2. Stryke (Acoustic Elegance) SB-12 Fs:21hz Qts: 0.557 Vas: 160 liters Vd: 742 cc Bl: 10.2 Sensitivity: 89dB @ 2.83v Nominal impedance: 6 ohms Xmax:14mm (1-way)
I WANT TO BUY SOME W22EX001s. PM me if you have some for sale! |
#2 |
There is not enough data for the AES SB-12 in your post. The Qts looks on the high side for a horn, and the Bl is on the low side. I took a look at the EPIC, it is not only discontinued, its T/S Parameters do not calculate correctly in Hornresp, anyway I build you a model for a 300 Liter tapped horn, maybe that'll get us started: Regards,
Oliver Last edited by tb46; 25th January 2011 at 03:27 AM. |
#3 |
WinISD driver file: Stryke Audio SAL-SB12.wdr
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#4 |
Paper mache horn fabricator
Just being practical: For the amount of effort it takes to actually fabricate a decent horn, I wouldn't waste time working with an inferior horn/driver combination. That being said, I'll take GM's data and see what I can come up with.
I enjoy audio so much that I constructed a web site. I share my ideas at: www.inlowsound.com |
#5 |
Here's what I came up with without going overboard on time:
#6 |
The horn was designed to be corner loaded. My experience with Hornresp is that it's very conservative. I have no trouble getting into the first octave, though Hornresp suggests the roll off is 35hz. YMMV.
#7 |
Ooops, forgot the most important:
#8 | |
Plan B is just to build some enormous ported boxes. 20hz, here I come!
#9 |
For your plan B you are looking at: BR - 117 ltr.net - 2 ports 4"Dia.x 20"long - for the EPD412, but it will not give you the same impact as a tapped horn (which is 2.5 times as large); and the volume is larger than Vas, which some people recommend against (impulse response looks fine in Hornresp though). Regards,
Oliver |
#10 | |
Did you say you have two of those subs? A pair of 12" drivers in a folded horn generally model better than one. Do you want me to continue with the modeling? John
| plexi tapped horn model | johnr66 | Subwoofers | 8 | 21st March 2010 09:20 PM |
| easy(ish) way to model the gain from a given BVR 'horn' | mondogenerator | Full Range | 1 | 22nd December 2009 02:15 PM |
| Single Driver Horn Base Port from Frugal Horn | EmergencyDpt | Swap Meet | 0 | 26th October 2008 01:24 AM |
| How to model various speakers with AJ-Horn? | freddi | Multi-Way | 0 | 16th February 2007 01:24 AM |
| question about mathematical model for the one dimensional exp. horn | toto2_6_49 | Full Range | 2 | 30th June 2006 08:53 AM |
| Page generated in 0.37029 seconds (28.75% PHP - 71.25% MySQL) with 11 queries |
