Old 23rd January 2011, 02:22 PM   #1
Bluto is offline Bluto  United States
Default TB W8740P
I've got 4 of these.
I've searched but can't find a design other than Bill's. I bought his plans but just too big for our small room ( 12 x 18 ).
I can't model. I've tried. Old Timers disease.
I'm intrigued by many tapped horns I see and slight alteration of dimensions make these work for fitment in room but I'm bright enough to realize this isn't the way to design a Sub.
Truth being I've owned 5 different Big Box Store subs and even at $400 a pop (JBL) I thought they all sucked as did my Wife. DIY simply has to do better.
We want clean, clear, crisp bass for music and would love to get to mid 20's for Music at 100 db . We'd be happy with high 20's- low 30's at 105 db for HT as long as it's clean. All we've owned has been able to rattle stuff but simply sounded like garbage.
A friend stated Jack Hidleys amps wouldn't power these & I've been thinking about Apex Sr.'s.
Anything Guys - I'd like to use these.
Old 23rd January 2011, 03:00 PM   #2
tb46 is offline tb46  United States
Default Tangband W8-740P
In geitmans' thread you can find the plans for the TH-SPUD, which is a Tom Danley designed HT tapped horn using two of these drivers:
Dual 8" tapped horn = TH-SPUD
If the box is to small, you can divide the cross-sectional areas by two, and maintain the length of the horn path, and arrive at a box for a single driver at about 1/2 the volume. You will then have to fold it to fit your requirements.
There are also other builds and simulations that you can find with the Google.
Oliver
Old 23rd January 2011, 07:09 PM   #3
tsloms is offline tsloms  United States
For a reasonably compact design using the Jhidley Foster amp see my build at this thread. It uses the MCM driver but it is close to your TB drivers.
http://www.avsforum.com/avs-vb/showthread.php?t=1240371
FYI--the Foster amp is an awesome match for the MCM driver that I used or your TB driver. They model rather close to each other.
Old 23rd January 2011, 07:53 PM   #4
I'm sure someone would model these for hornsresp for you.
I remember from another thread someone posted a screen shot of all the input parameters. He said use those then just change them around to fit your sub accordingly. Search for it on here...?
Old 23rd January 2011, 09:07 PM   #5
Default Dual 8 designs
There are lots of great options out there. This one is pretty cool:
JLH 20 Hz
I took that general idea, as well as some others I've come across, mixed it all up and came up with this:
Reed Shopsub
This does not go quite as low (~25 Hz corner), but gets plenty loud. It should - it is a larger enclosure. One should get past 115 dB at the listening position in a typical room on 300 watts and within xmax, but it will need a 25 Hz highpass to survive high-level home theater use. A pair in a room should literally break stuff when cranked up, Todd managed to break stuff with one.
Old 25th January 2011, 04:31 AM   #6
Thanks Guys -
Some good ideas here.
If anyone has any ideas for smaller one (28H X 22D x 10W) I'm all ears.
Old 25th January 2011, 05:28 AM   #7
Originally Posted by Bluto View Post
Thanks Guys -
That's pretty small. Probably not going to fit two drivers and a meaningful horn in that size box.
Could maybe fold up a 25 Hz single-driver horn in that space, but that is a lot of folding.
Let me check something...
Nope - won't work. Tried a 10" wide anarchy fold - this driver is not a good fit.
Old 25th January 2011, 06:18 AM   #8
Thanks Mike -
The Anarchy keeps calling to me - wondered if it would work.
Old 25th January 2011, 06:57 AM   #9
I took another look, tried narrower and wider cabinets, and it is just not a good fit. The W8-740 wants a higher throat to mouth ratio than that fold provides.
Old 25th January 2011, 11:52 AM   #10
JLH is offline JLH  United States
JLH's Avatar
I built a couple tapped horns with the W8-740C, which is an older model of the W8-740P. The T/S parameters given by Tang Band were off enough to make a difference in the tapped horn performance. Once the T/S parameters were actually measured, the desired results were much closer to the modeled predictions. If all possible, you should measure the T/S parameters of the drivers you have before actually building anything. It will save you a lot of trouble.
Ah, how beautifully the orchestra sounds before a rain! In a dry sunny day there is no way for the instruments to sound this way!
new fullrange by TB hm Full Range 35 4th January 2011 12:14 AM
I know they are new, but has anyone used/heard the new TB tweeters Arc Multi-Way 3 5th May 2008 07:54 PM
Neat New TB Sub... Godzilla Subwoofers 4 30th November 2005 11:19 PM
Which TB sub would you prefer? The Paulinator Subwoofers 5 27th October 2003 01:44 PM
TB projects. RAW Multi-Way 8 4th January 2003 08:19 AM
Page generated in 0.32019 seconds (30.45% PHP - 69.55% MySQL) with 11 queries
