Old 18th January 2011, 12:43 AM   #1
justint is offline justint  United States
Default 3015 lf box that plays down to 30hz??
anyone make one of these recently or is there a prior post.. i have a 3015lf that I would like to make a box for that needs to play down to 30hz with at least 115db. Doesnt have to play higher than 80hz. Any help would be great. Thanks
Old 18th January 2011, 01:32 AM   #2
Got something close, but not quite. According to the model, it is -3 dB at 33 Hz, and 115 dB is no problem at all.
Interested?
Old 18th January 2011, 01:36 AM   #3
jbell is offline jbell  United States
A few more requirements on size, etc would help.
A simple 200liter ported tuned to 30-32hz will do the trick.
(I happened to use 240cm2 port by 20cm long in hornresp@28v)
I'm sure mike has something better than this....
Old 18th January 2011, 02:43 AM   #4
smaller on size would be better as it is for the living room.. but yes send any plans specs you have .. Thanks..
Old 18th January 2011, 05:16 AM   #5
Small? 30 Hz? 3015 LF? Not gonna get all three. The 3015 likes a BIG enclosure, no doubt about that. I'm looking at 30" deep, 36" tall, and 23.5" wide, external. if that is too big, I can see if it is possible to squish the width any further.
This is a tapped horn, and is 100 dB 1W, 1M 2pi, -3 dB @ 33 Hz. 100 W gets you 120 dB @ 7 mm excursion, 250 watts is essentially xmax, at around 125 dB, 600 watts gets you north of 125 dB, within xmech.
30 Hz highpass is not an option.
Old 18th January 2011, 12:06 PM   #6
taller but not so deep? depth more like 20" area but I could go taller.. the width at 24" or less is fine. And correct I will not have a high pass.
Old 18th January 2011, 12:22 PM   #7
no high pass = no tapped horn
don't build it.
Any one here good at designing PR cabinets can give a suggestion for a cube with 3 of these?
http://www.parts-express.com/pe/show...number=295-496
Old 18th January 2011, 12:34 PM   #8
jwmbro is offline jwmbro  United States
jwmbro's Avatar
small footprint but tall? How about a single fold tapped horn.
20" x 20", but 5 and a half foot tall:
121dB with -3dB point at 30Hz. Highpass mandatory.
EDIT: oops, posted this before I saw that you don't have a highpass. Could get about 115dB within xmech, but exceeding xmax below 21Hz if you didn't use the highpass with it.
Regards, James
Old 18th January 2011, 07:02 PM   #9
ok so any other suggestions besides the tapped horn? or I guess i could buy a amplifier with a high pass?
Old 18th January 2011, 07:19 PM   #10
Passive radiators don't have the unloading issue below system resonance that ported or tapped horns have.
A Jurassic Park T-Rex stomp turned up in a TH without a high pass = one very cooked driver.
I'm kinda intrigued by a 3015lf / PR design, and may spend some cycles investigating it.
The rule of thumb is that you need 3x the Vd of your driver, in your PR's. 3 of the dayton 12's @10mm xmax each doesn't quiet get you there, but it's close. (and they are cheap)
A PR design would allow you a small enough box to be allowed in the living room as well.
passive 30Hz-20kHz Bandpass filter for tube preamp? erer4 Tubes / Valves 5 20th October 2010 07:45 AM
30hz 10" tapped horn magic? killerfishes Subwoofers 10 27th December 2009 05:53 AM
Alpine DIN to RCA conversion for older EQ's 3015. tomtomjr Car Audio 0 28th April 2009 09:22 AM
Eminence Kappalite 3015 as open baffle bass? EC8010 Multi-Way 4 29th June 2007 08:05 AM
30Hz tuning for Peerless XLS 12 inch Glen1 Subwoofers 0 8th December 2005 09:45 AM
Page generated in 0.13826 seconds (62.18% PHP - 37.82% MySQL) with 11 queries
