Old 13th January 2011, 01:47 PM   #1
comasus is offline comasus  India
Default sub-woofer enclosure
please give me the sub-woofer enclosure dimensions for the following woofer
Ahuja Sound Solutions
Old 14th January 2011, 02:14 PM   #2
I'd like to help, but need some more info. What cab alignment are you wanting to utilize.....sealed, vented, BP, horn, etc.? Do you already have the driver, if so bear in mind that with a qts of 0.3 that driver is going to fall like a brick below fs, and doesn't have enough xmax to eq the low end in a more conventional cab......really needs a horn IMO. I assume you're limited in India as to what is cost effective shipping wise........this is a much better choice from the same distributor........http://www.ahujaradios.com/ProductSp...&id=7&sc_id=48
Old 15th January 2011, 12:13 AM   #3
Originally Posted by steviedon View Post
I'd like to help, but need some more info. What cab alignment are you wanting to utilize.....sealed, vented, BP, horn, etc.? Do you already have the driver, if so bear in mind that with a qts of 0.3 that driver is going to fall like a brick below fs, and doesn't have enough xmax to eq the low end in a more conventional cab......really needs a horn IMO. I assume you're limited in India as to what is cost effective shipping wise........this is a much better choice from the same distributor........Ahuja Sound Solutions
hello sir
i want to use this for out door purpose (200 people gathering) so you decide me the cab alignment
i have already purchased driver
thank you
Old 16th January 2011, 02:35 AM   #4
djk is offline djk
djk's Avatar
I think I would use that in the SS15 tapped horn.
Single sheet TH challenge
Candidates for the Darwin Award should not read this author.
Old 16th January 2011, 04:42 AM   #5
Thawach is offline Thawach  Thailand
Thawach's Avatar
my experience from thai people. bp6 [18"*4] can play with party about 70 table. one table is about 5-6 persons. therefore people are about 400 in party.
with ur driver is very low x-max. i think this driver play midbass more than low deep. the possible likes djk said cubo is the best way to go. horn can increase spl with the low x-max more than any types. the cubo i think that's very hot now. last week i post on thai forum but use with p audio.
*out of the past=out of the future=in the present time+ing*
Old 16th January 2011, 09:44 AM   #6
chris661's Avatar
Agreed. The low Q could really use a horn.
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 16th January 2011, 06:20 PM   #7
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Default Horn(or TH)
Fyi:
b
when designing a 2 woofer enclosure... slicemaster101 Multi-Way 33 5th April 2012 05:55 AM
the TL (sub)woofer enclosure sergiof Subwoofers 4 17th July 2010 08:47 PM
Small Enclosure Woofer h_andree Multi-Way 5 28th March 2008 09:25 AM
Please recommend enclosure for this woofer Cro maniac Multi-Way 3 4th August 2004 12:22 PM
Woofer sound without enclosure gchrist Multi-Way 5 10th November 2003 07:32 AM
Page generated in 0.45232 seconds (19.44% PHP - 80.56% MySQL) with 11 queries
