I have a Polk PSW1000 (PSW1000 Product Page : Powered Subwoofer : Polk Audio) box and drivers and M&K VX-1250 amp (http://apexjr.com/images/MK_sub_VX-1250_manual.pdf).
Each driver is 3.5 Ω/88 db. Should I connect them in series with this amp? Or would it be able to handle a 2Ω load in parallel? Also, the manual says to run the subwoofer output from my receiver to the left rca input, and that I don't need the right. With two speakers should I use both the left and right? Last edited by jordyyy; 11th January 2011 at 11:36 PM. |
#2 |
I don't think the amp can handle 2 ohms. Will running them in series have any effect on the sound? because the are not dvc. If I run the left and right from the receiver instead of just the left, and the speakers are wired in series, will it drive them as 2 individual subs?
#3 |
| M&K sub amp for Polk psw1000? | jordyyy | Subwoofers | 1 | 15th November 2010 07:13 PM |
| Bridge & Parallel 4 x LM4780 - Basic wiring diagram needed | GAH | Chip Amps | 13 | 12th August 2009 01:37 PM |
| Three 10" 4Ohm subs, wired in series or series-parallel? | Nagamitsu | Car Audio | 24 | 10th May 2009 03:24 AM |
| Tweeter from B&W series 800 series 3 | pirat | Multi-Way | 3 | 1st May 2005 07:39 PM |
| Parallel amps & Parallel Voice coils? | officeboy | Multi-Way | 7 | 26th May 2004 07:12 PM |
| Page generated in 0.08525 seconds (68.63% PHP - 31.37% MySQL) with 10 queries |
