Sealed subwoofer system
Navin,
The better question would be: Just how big of a tranny does a
350 to 500 watt monoral amp need?
The plate amp I run is 500 watts RMS Mono and runs a larger
toroid than most class A two channel amps. Alternately most of
these sub amps run in Class A/B or G and D I believe and they are
all certainly more efficient than a pure class A amp though some
would argue not as "musical" but for sub frequency use what is
exactly audible? Drivers can make as much as 40% distorsion and
I don't think the human ears can even pick up on this, a measurement
mic can.
I guess it's all in what you want.. I am into HT and 2Channel and
because of this I need a large excursion driver to produce lower
than 20Hz info in movies... For music you never see much below
the 30's unless it's Pipe Organs. A high sensitivity modest excursion
driver certainly "can" work given the right enclosure and tunning.
In the end, like everything else it all boils down to preference or
design philosophy.
If I told you what I paid for my Carver Sunfire plate amp you
would smack me :) It's from an OEM'd sub and the company (AR)
was selling off thier parts replacement stock to a surplus company.
Believe it or not.. I paid a whopping $54.00 for a brand new
sealed 500 Watt RMS Bob Carver Sunfire TDC Sub Amp with a
Variable 40-120Hz XO and a Audio/Video Selector (Video adds
Bass Boost, Audio is Flat) Plus Gain Control. It was meant for
the European Models (240V) but luckily I have a 220V Receptacle
in my Living Room. :)
But I agree my luck is not the standard.. But you can still buy
QSC or Crown Pro Amps cheaply and add a Behringer Feedback
Destroyer for EQing...
Bass Boost, Audio is Flat) Plus Gain Control. :)
You've been robbed, Brett. If the company won't refund your hard-earned money, I am prepared to reimburse your original stake - only because I feel strongly for the victims of this sort of scam.
Guys
Here is the graph from WinISD...ORANGE line is with two lambda SB15 drivers, 390 liter box. (smaller box increased loss at 20hz and raised a peak in the 40-50Hz range and if I got even smaller, I lost more at 20Hz...go larger didnt do too much.
Thoughts on this graph? Figured between room gain and equalization, I can raise the 20 Hz -6dB loss. But I keep my sealed system with low group delay.
The GREEN line is a ported system using Lambda PB15, same size enclosure, tuned to 22Hz. I prefer the sealed.
