Sealed subwoofer system
Old 23rd July 2003, 01:02 PM   #11
Brett D. is offline Brett D.  United States
Send a message via ICQ to Brett D. Send a message via AIM to Brett D. Send a message via Yahoo to Brett D.
Navin,
For subs? Nope.. You don't need some esoteric "high end" amp
to drive a sub woofer.. Any amplifiers distorsion figures will be
far better than a subwoofers distorsion. I'd stick with the elite,
expensive amps on the top end.. Use Pro or Plates for the subs.
But that is, as always just my opinion and YMMV
Old 23rd July 2003, 01:04 PM   #12
navin is offline navin  India
navin's Avatar
Send a message via MSN to navin Send a message via Yahoo to navin
dont those plate amps have awfully small power supplies. i thoguth you need a lot of curent dumping capacity (read as big power supply) to feed subs. yes you might not need class A but a big power supply is certainly required. and these are expensive.
...still looking for the holy grail.
Old 23rd July 2003, 01:07 PM   #13
kelticwizard is offline kelticwizard  United States
Wizard of Kelts
diyAudio Moderator Emeritus
What Navin is trying to say, and I have had the same thoughts, is that when you take a look at some of these superheavyweights and see such low sensitivities, you have to wonder if you wouldn't be better off with a small excursioned driver and a smaller amp.
At some point, the sensitivity is so low that you never get to use the extra excursion because your maximum rated power has run out. When you have your amplifier having to play 500 watts to achieve the same SPL that a more efficient driver only has to play 125 watts to achieve, the SPL won't be that high when the maximum power input is achieved.
This is another argument in favor of ported subs, which cut cone excursion by 4 at the resonance point. This allows the use of a shorter voice coil, therefore makes for a more sensitive sub. However, ported is not necessarily the best choice in every subwoofer application.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 23rd July 2003, 01:10 PM   #14
7V is offline 7V  United Kingdom
7V's Avatar
Originally posted by kelticwizard
Here is a link to a chart of Room Gain. This is an approximation-other charts will differ slightly.
It's all guesswork because of the room and it's modes anyway, but at least you can get an idea.
http://www.speakerbuilding.com/content/1020/rge.gif
So, roughly speaking you're 5dB down at 20Hz (relative to 30Hz). When you take into account the dramatic frequency peaks and troughs brought about by room resonances at bass frequencies I would say that this 5dB is, in practice, virtually insignificant.
Also, if you're planning to place a single subwoofer in a corner of the room in order to couple it to the room (a reasonable approach) then you can assume that the sub would be boosted by the room. You would probably need approximately 3dB less than the maximum SPL of your main speakers (+6dB for the room, -3db because there's only one sub but two mains).
Old 23rd July 2003, 01:15 PM   #15
Wizard of Kelts
Originally posted by Brett D.
It's highly unlikely that a
driver with a robust suspension will have a short voice coil as that
goes against what it was designed for.
That being said, give me the large excursion driver any day, no
matter what the sensitivity is.. I don't even consider sensitivity
unless I am looking at midrange and tweeters.
Brett:
Actually, the example I gave of a 0.5" voice coil really wouldn't be adequate for any sub that anyone would want. What I meant was, when you have a choice between a 1" excursion, (midpoint-to-extreme) sub of 84 dB, and a 0.5" excursion, (midpoint-to-extreme) sub of 88 dB, you might be better off going with the more efficient sub in terms of maximum SPL's produced at the lowest frequency.
Everything is a balance.
-Anonymous
Old 23rd July 2003, 01:44 PM   #16
subwo1 is offline subwo1  United States
subwo1's Avatar
Brett:
Some woofers may get a boost in SPL rating by using tighter suspension, not more flux on the voice coil.
USMPS
http://groups.yahoo.com/group/switchmode/
Old 23rd July 2003, 06:15 PM   #17
navin's Avatar
thanks kelticwizard
Old 23rd July 2003, 07:58 PM   #18
DIY_Peter is offline DIY_Peter  Belgium
Originally posted by navin
Ex: Driver with Xmax 27mm sens is 84db, Driver with Xmax 13mm Sens is 89db and Driver with Xmax 9mm Sens is 92db (all these 3 are well known 12" drivers).
Xmax=27mm?? You mean +/- 27mm?
I thought that +/-10mm was already a very high Xmax, like the Peerless XLS range.
Which drivers are you refering to Navin?
Old 23rd July 2003, 08:17 PM   #19
navin's Avatar
i saw them on the net. i guess one of the others will have a link. i dont use bookmarks.
Old 23rd July 2003, 08:49 PM   #20
Wizard of Kelts
I believe the Blueprint 1503 and 1203 had Xmax 25 mm, in fact a little over. Then there is the TC Sounds with linear excursions 1.5 inches. Adire has a huge subwoofer that is 1 inch as well.
I am not certain, but I think one of the models of Strykes is made by TC Sounds. It could be the very model this thread is about.
And yes, even 10 mm is very good. It used to be the best subwoofers around had excursions of 0.25", (6mm), until the Excursion Race started about a dozen years ago.
http://www.tcsounds.com/
http://www.adireaudio.com/diy_audio/...ire/tumult.htm
-Anonymous
Sealed subwoofer systemHide this!Advertise here!
FR8C 25lt sealed mid-high in active bi-amp system col Multi-Way 0 17th June 2009 12:15 PM
how to connect a non powered subwoofer to a stereo system without a subwoofer output JSD777 Multi-Way 4 20th September 2005 03:19 PM
Would ported or sealed enclosure be best for this driver in small PA system? The Paulinator Multi-Way 26 25th April 2004 03:38 AM
Sealed Box Subwoofer Recommendations Javaman Subwoofers 12 21st December 2001 01:25 AM
