Cheap 10inch woofer in tapped horn? what would you do?
Old 31st December 2010, 06:03 AM   #1
ThyDntWntMusic is offline ThyDntWntMusic  Australia
Default Cheap 10inch woofer in tapped horn? what would you do?
figured I'd ask for peoples ideas and suggestions, I've already modelled a few boxes, but thought I'd hear what other people might do
also make it easier for me to keep track of the specs, which are manufacturer supplied, although I'd like to measure them for myself some time.
* Power: 300W RMS
* Peak Power: 600W
* Frequency Response: 40Hz - 1.5KHz
* Sensitivity: 87dB/1m/1w
* Fibreglass Composite Subwoofer Cone
* Vas: 26.903
* Impedance: 4 ohm
* Qms (Mechanical Factor): 3.312
* Qes (Electrical Factor): 0.478
* Qts (Total Q-Factor): 0.418
* Fs (Resonance): 45Hz
assuming we measure half the width of the surround when calculating the sd, the diameter is 20.5cm, so SD is 330cm^
re measures 4.2ohms
and most importantly, they're purdy! so I'd like to have the cones on display
Old 31st December 2010, 06:30 AM   #2
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
my, they must be stiff as hell
car woofers, surely
if they are all yours, make two line arrays, closed, and lots of Eq
Xmax ?
Old 31st December 2010, 06:35 AM   #3
car woofers, surely
Xmax ?
I don't discriminate against "car" and "home" woofers.
there really isn't a difference, they both have magnets and coils!
don't know X-Max, I'd guess somewhere around 5 - 10mm one way
I've currently got them modelled in a 2.4m long (total) tapped horn.
165cm^ throat, 330cm^ mouth, with the woofer 15cm from each end.
it gives a theoretical 103dB 1w down to 40Hz, but the mouth just seems way too small to yield that kind of efficiency.
Old 31st December 2010, 08:05 AM   #4
the aim is 150dB, at 30Hz, in a 4 meter X 6 meter room...
I wanna do hair tricks!
Old 31st December 2010, 09:54 AM   #5
chris661 is offline chris661  United Kingdom
chris661's Avatar
How many drivers do you have?
You will need a very very very large horn to get 150dB@30Hz. With the 300w power rating of one driver, you'd need a starting efficiency (when horn loaded) of around 125dB (at one watt). Let's not get started on the excursion at that much power.
It sounds to me like you'll need more than one driver.
Chris
My work: www.grimshawaudio.com
Old 31st December 2010, 10:02 AM   #6
Chris
Old 31st December 2010, 11:16 AM   #7
David_Web is offline David_Web  Sweden
If room gain will add another 12dB (and corner placement is lossless) it could be done.
I would suggest four TH with four drivers each.
I landed around 336L internally per box.
S1 600 and S4 1500. Par. 320cm total length.
As you already have the drivers, go for it. You can't really beat much more performance out of them anyway.
If you didn't try to press so much SPL out of them 8 T-TQWT (with two drivers each) would be neat for a HT.
Old 31st December 2010, 11:30 AM   #8
from playing with horns before, I don't expect any room gain, but I do expect it to lower the frequency response slightly.
I had modelled a simple, single fold 240cm horn, with eight woofers in it...
one thing I noticed though, was that if I doubled all the "S" figures, and the number of woofers, hornresp suggested that the frequency response would change, and it would play lower...
is this correct?
Old 31st December 2010, 05:46 PM   #9
mashaffer is offline mashaffer  United States
Odd that a driver intended to be used below 1.5K Hz would have a phase plug.
Generic Signature
Old 31st December 2010, 10:09 PM   #10
Brian Steele is offline Brian Steele  Grenada
What brand/model are those drivers, and how much did they cost?
Cheap 10inch woofer in tapped horn? what would you do?Hide this!Advertise here!
WTB: 6.5" woofer to replace broken woofer in cheap band pass subwoofer Jimmy154 Swap Meet 2 5th October 2010 03:00 PM
Tapped Horn Feeding A Unity Horn Patrick Bateman Multi-Way 20 4th September 2010 02:27 PM
Can a Tapped Horn have a negative taper within the horn path? BP1Fanatic Subwoofers 6 13th February 2010 07:04 AM
Lab 12 Tapped Horn, Ron's Austin II, T-Horn, CNC Photo Background layertone Subwoofers 15 23rd January 2010 06:12 AM
Ron's Austin II, old T-Horn, Lab12 Tapped horn, CNC Photo Background layertone Full Range 2 23rd December 2009 01:51 AM
