Old 22nd December 2010, 08:04 PM   #1
Default eminence sigma pro 18 in the house ?
hi guys, I just want to know what you thing about sigma 18" driver for home environnement? with about 200watt/8ohm amplifier
it will be for 95% musique and live music show on dvd. 5% movie.
I'm limited to 180-200 liters box (probably use the recommeded BR 7cu/ft box from eminence f3:40htz)
I'm a newbie with PA woofers. i know it will be not go realy down but it's for ALL type of music.
I look for large diameter driver but cheap price if you have another suggestion
thank you.
jee.
Old 22nd December 2010, 08:28 PM   #2
Boscoe is online now Boscoe  United Kingdom
I think you would be better off doing a horn design like I am, I don't have the money or room for 18" drivers so I'm doing THIS design. There are also designs for 15" drivers with are supposed to be able to beat 18" of similar power levels I think.
There are also a lot more horn designs of course!
Old 22nd December 2010, 08:58 PM   #3
yes, I look abaout the cubo 15 and 18 , this is very interesting.
I'm not familiar with this type of box, what is the biger differance compare to a BR for example?
jee.
Old 22nd December 2010, 10:17 PM   #4
I don't know that much but there are others in this section of forum who will be very able to tell you in detail but I can tell you they are a type of rear loaded horn they are pften called hybrids.
I can't teall you about horn theory I have no clue but they are supposed to yield very good sensitivity.
I thought about it once, but then thought again.
Old 23rd December 2010, 12:50 AM   #5
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
FYI:
Hi-Fi...Lo-FI comparison:
b
File Type: jpg EminenceSigmaPro-18A2-T-TQWT-vers_Cubo15.JPG (627.1 KB, 190 views)
Old 23rd December 2010, 12:54 AM   #6
nigelwright7557's Avatar
I use one for home and disco use.
I love the bass response from this speaker.
If I remember correct it also works upto 2.5KHz.
I complement it with a midrange 4 by 10inch cabinet for mid to high frequencies.
I just used a basic box with a 4 inch vent in the rear.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 23rd December 2010, 09:13 AM   #7
djk is offline djk
djk's Avatar
About 6 cu ft (net) with the port tuned to 28hz and a high-pass filter with a Q=2 at 28hz will give you a -3dB point of 28hz with the SIGMA PRO 18A-2.
Most common plate amplifiers have a hi-pass filter than can be changed as per the above requirements.
Candidates for the Darwin Award should not read this author.
Old 23rd December 2010, 02:24 PM   #8
I don't know how you get 28htz in F3, I make a simulation with BBpro and it give me 62htz with your specs.. how you get that ?
jee.
Old 23rd December 2010, 03:24 PM   #9
I have also an active controler for subwoofer, (with:high-cut, low-cut, bass boost etc)
jee.
Old 23rd December 2010, 11:05 PM   #10
djk is offline djk
djk's Avatar
"I don't know how you get 28htz in F3, I make a simulation with BBpro and it give me 62htz with your specs.. how you get that ? "
"and a high-pass filter with a Q=2 at 28hz "
FS: Eminence Omega Pro-15A truenorth Swap Meet 0 29th April 2009 12:53 AM
Eminence Sigma Pro-18 Xmax? Evan Andersen Multi-Way 16 4th April 2008 02:08 PM
Subwoofer Pro Eminence Omega 18 (EPS18-600)??? goodspeaker Subwoofers 6 6th July 2006 11:44 PM
Eminence Kappa Pro-12 tom_nice Swap Meet 1 26th February 2006 11:30 PM
Enclosures for Eminence Sigma 18" and/or Eminence Kilomax 15", PA-sub application esaias Subwoofers 8 10th August 2005 05:17 AM
Page generated in 0.14116 seconds (66.75% PHP - 33.25% MySQL) with 11 queries
