Old 20th December 2010, 04:37 PM   #1
Frode is offline Frode  Norway
Default Which enclosure for cheap 18"?
What enclosure would you recommend for this driver: http://www.mamut.net/dynabel/pa1880-1000-web.jpg?
I'm thinking of subwoofer duty in home environment, no need for high SPL. Enclosure can be fairly large, several drivers can be used.
Frode
Old 21st December 2010, 12:14 AM   #2
Haven't simulated it but a quick look seems to indicate horn or possibly bass reflex. Q is a little low for sealed IMO. Not a lot of xMax but with 18" it may not be needed. The question in a horn would be whether the cone structure is strong enough for the pressures. Sometimes that can be a problem with large drivers. Other than asking the manufacturer I do not know how you would discern this by yourself.
Now that I think about it the fs is probably a little low for a horn anyway (Unless you are after subsonics primarily). I would model some ported enclosures and see how it comes out. Free software like BoxPlot et.al. are very nice for this purpose.
mike - www.keepingsundayspecial.org
Old 21st December 2010, 04:21 AM   #3
Thawach is offline Thawach  Thailand
Thawach's Avatar
very big 18" in home. no need the high spl. the bass reflex is better than anything.
*out of the past=out of the future=in the present time+ing*
Old 21st December 2010, 04:43 AM   #4
GM is offline GM  United States
GM's Avatar
Guess it depends on what sort of performance you're after. For instance, four with 400 W on tap in 20 ft^3 tuned to 16 Hz has enough theoretical peak SPL to either blend to some room gain and/or EQ it flat all the way down or meet THX cinema reference down to 25-30 Hz. Trade some peak SPL for more damping to further 'tighten' it up to better mate to horns.
Or you can use two drivers/400 W/20 ft^3 in a TH to get similar results to 80-100 Hz.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 21st December 2010, 03:54 PM   #5
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Default dynaBel PA-1800_T-TQWT
FYI:
b
Old 21st December 2010, 09:47 PM   #6
GM
20 ft^3 per driver or for all 4?
Frode
Old 21st December 2010, 09:59 PM   #7
GM's Avatar
5 ft^3 net/each
GM
Old 21st December 2010, 10:03 PM   #8
5 ft^3 net/each
GM
This sounds good. I said they could be fairly large, but 4 times 20ft^3 would be stretching it! Merry Christmas to you Greg!
Frode
Old 22nd December 2010, 01:24 AM   #9
GM's Avatar
Ah! So it is you! The City of Bergen didn't 'ring any bells' with me.
Merry Christmas to you also! ('Sounds' strange nowadays, what with all the political correctness 'forcing' folks to use 'Happy Holidays')
Well, you know me, 20 ft^3/dual 15" is just a good starting point for getting serious, but your horns already take up a sizable percentage of living room 'real estate' if it's the same as you sent pics of several years ago.
GM
Old 22nd December 2010, 08:58 AM   #10
Thawach's Avatar
Frode
post pics here if it's finish. i want to see the big speaker. after i post i forgot to saw the "fairly large" good luck to build Frode
Where's the bass from an 18" Audiobahn AW1805Q in a 12cf vented enclosure? Max Caliber Subwoofers 45 12th April 2011 04:53 PM
18" Folded Horn Enclosure the_kelso Subwoofers 12 12th February 2006 07:53 AM
seek advice on enclosure for 18" subwofer joekjtam Subwoofers 1 10th January 2005 04:19 PM
Good and "Cheap" enclosure for scan 8565? foo Multi-Way 2 9th January 2005 03:54 AM
Page generated in 0.14372 seconds (69.19% PHP - 30.81% MySQL) with 11 queries
