Cube horn design?
Cube horn design?
Old 13th August 2011, 02:45 PM   #41
Boscoe is offline Boscoe  United Kingdom
How do I sim this in hornresp? I'm unable to use hornresp because of my 64bit OS.
Audio projects and more: gswdh.co.uk
Old 13th August 2011, 03:07 PM   #42
epa is offline epa  Netherlands
i use win 7 64 bit and hr without probs,noting special neede ,just run the exe
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 13th August 2011, 03:33 PM   #43
Sorry I meant I can't use akabak. I can use hornresp.
Old 13th August 2011, 11:49 PM   #44
Zero D is offline Zero D  United Kingdom
Default Akabak
@ Boscoe
Hi, can you try this ? In Program Files, or wherever you installed Akabak to, locate Akabak.exe and right click on the icon for it, then see if this works !
Old 14th August 2011, 08:30 AM   #45
if u want to use hr,it should be moddeled like this.(i think)
its not the cubo but the same principal
. hr driver db
Old 14th August 2011, 08:53 AM   #46
Originally Posted by Zero D View Post
@ Boscoe
Thanks but I had already tried that for all versions of windows from NT to XP.
Old 14th August 2011, 09:42 AM   #47
So is S1,S2 as normal then? What's the top right hand smallest arrow for?
Old 14th August 2011, 01:25 PM   #48
top right = s1=s2 ,L1>L2=0.1cm
. hr driver db
Old 24th August 2012, 08:02 AM   #49
grec13 is offline grec13  United States
Thumbs up Cubo 12
Aloha.
I build double version of Cubo 12.
Let me tell you something.
First of all -you NEVER expect so much bass from such small cabinet.
Second -That litle monster KIKS!
And third - the sound...
It's very fast, detail and deep in the same time.
You can feel the waves of sound coming trough your body even on low volume level.
The only weakness is that it limited by 45 (may be even 50) hz up to 140hz.
The quality of sound and output is very close to basshorn.
But in this size?!
Very, very nice sounding cabinet!
Now I'm interested in Cubo18 sub. That going to be something...
Originally Posted by Boscoe View Post
Rademakers would you be able to design me a cube for a 12 inch driver? I would like to be as small as possible and only needs to go to 150Hz as a sub. Can I choose a driver? If so what would be ideal.
Thanks a lot.
Boscoe
EDIT - don't worry sorry just looked through the thread afterwards! Are there plans for the cubo 12?
EDIT - Don't worry again just found it! I should look through before I post!
Sergey
Old 28th September 2012, 07:43 AM   #50
Originally Posted by grec13 View Post
and it works UNBELIEVABLE!
A lot of air moving and kicks!
Very high quality sound.
I'm wonder what is the frequency range for Cubo 18 sub?
Sergey
Cube horn design?Hide this!Advertise here!
Need help with horn design djn Subwoofers 1 29th August 2010 05:09 AM
Help me design a horn unknownuser200 Multi-Way 23 2nd September 2008 01:14 PM
Horn design? lemans23 Multi-Way 12 28th March 2007 04:12 AM
how to go from horn response to a folded bass horn design? paulspencer Subwoofers 8 4th November 2005 10:44 PM
new horn design exurbia Multi-Way 3 2nd July 2002 12:59 PM
