Cube horn design?
Akabak
@ Boscoe
Hi, can you try this ? In Program Files, or wherever you installed Akabak to, locate Akabak.exe and right click on the icon for it, then see if this works !
Cubo 12
Aloha.
I build double version of Cubo 12.
Let me tell you something.
First of all -you NEVER expect so much bass from such small cabinet.
Second -That litle monster KIKS!
And third - the sound...
It's very fast, detail and deep in the same time.
You can feel the waves of sound coming trough your body even on low volume level.
The only weakness is that it limited by 45 (may be even 50) hz up to 140hz.
The quality of sound and output is very close to basshorn.
But in this size?!
Very, very nice sounding cabinet!
Now I'm interested in Cubo18 sub. That going to be something...
Rademakers would you be able to design me a cube for a 12 inch driver? I would like to be as small as possible and only needs to go to 150Hz as a sub. Can I choose a driver? If so what would be ideal.
Thanks a lot.
Boscoe
EDIT - don't worry sorry just looked through the thread afterwards! Are there plans for the cubo 12?
EDIT - Don't worry again just found it! I should look through before I post!
Aloha.
But in this size?!
where do u get the plans ,i can only find the single driver version
As far as performance is considered there are no real advantages for either two single or a double Cubo.
When it comes to transport, lifting, build-up, etc. each had it's own advantages. A double can be made slightly smaller and lighter as two singles.
Technically you could also lessen the bracing as the forces on the divider panel are opposite from both drivers.
Best regards Johan
