Old 16th December 2010, 01:58 AM   #1
Thawach is offline Thawach  Thailand
Thawach's Avatar
Default the 4th order is it correct?
hi all
i find this box, they tell 4th order i see the 2 port very bid in the front of this box. the specs use 18" driver. it make me surprise that why i can see the driver inside in the same line level. i want to know is it bandpass or bypass sub. i think it can bypass the high freq to outside. is it correct design?
Old 16th December 2010, 10:29 AM   #2
epa is offline epa  Netherlands
Originally Posted by Thawach View Post
hi all
looking @ the pic i say its a 4th order bandpass with the driver reversed(propably to make the box less deep)
and yes you can always filter it outside the box.
Old 20th December 2010, 10:06 PM   #3
Thawach's Avatar
i try to see somewhere that the port location's in front of the drivers. they have a little to design. i consider that if the port like this. the pressure of the air will drop very fast and may not has the deep bass. ok i'll not design like this
*out of the past=out of the future=in the present time+ing*
Old 13th January 2011, 08:36 PM   #4
Thawach's Avatar
friends a bit problem when i see this sub. it seems like bp6. but why behind the subwoofer they design like the horn but outside it has the port. i want to know the design can increase the spl output?
Old 16th February 2011, 05:01 PM   #5
Thawach's Avatar
surprise again! this box seems like bp4. i think why people like to build it. i simulate with HR und win isd. the respond freq seems peak a lot at the upper bass. all friends i want a lot of ur comments about this respond.thank u
Old 16th February 2011, 05:02 PM   #6
Thawach's Avatar
and with HR
Old 16th February 2011, 06:34 PM   #7
that response doesn't look very good....
Old 17th February 2011, 03:24 AM   #8
Thawach's Avatar
i considered a long time why they still build it. i try to see the EAW sb1000 when it does not unprocess. still likes the upper bass freq region but when low respond freq. i see the graph EAW sb1000 better than very much.
i see from this specs sheet
EAW specs sheet
Old 17th February 2011, 03:55 AM   #9
yeah thats what i meant, the lower frequency response
Old 17th February 2011, 07:42 PM   #10
Thawach's Avatar
from this graph i guess that they only want the upper bass to throw away. it's possible that i think. or only want the sound of kick drum bass more than low. but again i think they use EQ to boost the low likes EAW do with EQ processor.
LR 4th order vs LR 8th order crossover redliner Subwoofers 1 7th January 2009 11:32 PM
My 1st order butterworth filter better than 4th order L-R: Why? philipreji Solid State 61 1st March 2007 04:50 PM
4th Order Bandpass Help berserker Subwoofers 9 19th January 2007 03:56 PM
4th order bandpass 4 way the phantom Multi-Way 3 27th July 2005 06:28 AM
4th order Subwoofer Ilianh Subwoofers 18 3rd November 2002 03:33 AM
Page generated in 0.10154 seconds (80.92% PHP - 19.08% MySQL) with 11 queries
