Decided I need a sub for music that will fill the gap from 20-80Hz created by using full range drivers in single driver enclosures. Here's what I have come up with, hopefully to be completed before Christmas or at least for the new year. This sub will always be in a corner so decided to model in 0.5 Pi, but the response is still just as flat in 2 Pi just with less extension and obviously much less efficiency.
Any comments on the design are greatly appreciated. |
#2 | |
b |
#3 |
Outstanding work as always bjorno!!
#4 |
Awesome designs bjorno, so you think a 30Hz shoulder is better for music than 20Hz? Also what is the SPL response combined window telling me?
#5 |
After tweaking the original abit and then changing the values to suit the plan I came up with in sketchup I got a response that was a bit smoother. I tried to plan your designs bjorno but fitting the driver in seemed to be a bit of a challenge, I guess thats the joy of working with 15's.
#6 | |
The FR looks better and the gldy looks good too;To be sure if your design is good, please post the HR input screen and yes 30 Hz IMO is low enough for most music (hint: look at f-10dB for typical in room experienced BW). See my simple picture suggestion on how to fold a T-TQWT for easy driver maintenance and for easy accessing (tweaking) the stuffings: b |
#7 |
Here is the HR input for the plans posted above. The width of the enclosure is 400mm.
#8 |
Forgot yesterday to post this picture belonging to 'LB1560_Home_xmax=11mm-test2', see the first picture. Picture#2 is your final design, picture#3= Home TH suggestion and picture#4, #3 and #4 for closer IR examination using HOLMImpulse program. b |
| All I Want For Christmas.. | djdowdell | Introductions | 1 | 25th December 2006 04:49 PM |
| Christmas greetings | Jim Karr | The Lounge | 4 | 25th December 2005 01:46 AM |
| Project for christmas... | Paprika | Solid State | 4 | 21st November 2003 07:50 PM |
| Christmas is here! | Corn-Picker | Everything Else | 20 | 28th December 2002 03:27 AM |
| Page generated in 0.09627 seconds (80.58% PHP - 19.42% MySQL) with 11 queries |
